08-16-2010, 08:28 AM | #1 |
Newbie Join Date: Aug 2010 Location: Gloucester
| Servo glitch?
Thanks for the help on the other question. The problem is when the wheels are hard left or right under a load, the servo starts to glitch and i lose all funtions. I pickup the truck and it stops glitching and is fine. Is that a servo problem or a radio adjustment? The batteries in the radio only last about a couple hours? I'm running a CKRC MG995 servo, Dura Trax Auto Sport ESC, Venom VRST Radio,55t Motor, 7.2V 1800mAh battery. Thanks, Mike. |
08-16-2010, 08:47 AM | #2 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
get a BEC .that will sove it
08-16-2010, 09:48 AM | #3 |
I was going to get a lipo cut off module to run a lipo. Will the BEC do the same thing?
08-16-2010, 04:38 PM | #4 |
08-16-2010, 04:44 PM | #5 |
Pebble Pounder Join Date: Dec 2005 Location: Coopersville,MI.
Wow the batteries in your controller only last a couple of hours? Mine last a few weeks at least running them everyday... Maybe something wrong with your controller. Try a different one.
08-16-2010, 06:49 PM | #6 | |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
X2 Some radios are pigs man | |
08-16-2010, 10:20 PM | #7 |
Quarry Creeper Join Date: Jan 2010 Location: north phoenix
x3 on the bec just got mine in and it great..... but i think to save your self the headache in wiring i would just upgrade your esc (if funds are not an object) but deffinitely save the weight dump the cell and go lipo....
08-16-2010, 10:32 PM | #8 |
| Yea but even some of the higher end esc's(fxr, sidewinder, mmp etc) still need them when your running high power/torque/multiple servos and if your running 3s and above. The only esc where you might be able to use a high power servo and no bec is the HH Torque Master pro....but to what extent i dont know
08-16-2010, 10:40 PM | #9 |
thats what im saying (if funds are not an object).....
08-18-2010, 09:09 PM | #10 |
| http://www.ckrccrawlers.com/novak-30...-bec-p-78.html http://www.ckrccrawlers.com/5465-nov...bec-p-689.html Thanks for the help guys, Would one for these work? Is one better than the other? Why? I know I know to many questions. |
08-18-2010, 09:24 PM | #11 |
No you need a 10 amp or bigger,,,both of those are like just using the esc
08-18-2010, 09:33 PM | #12 |
Here you go. this is the one you need Castle Creations BEC This is the one most everyone uses |
08-18-2010, 10:11 PM | #13 |
Quarry Creeper Join Date: Dec 2006 Location: Tasmania
The Castle BEC is the stuff. You do need to get the Castlelink to set it up, but you should have one, for all the Castle ESC's you should have Ok, that was sprooking, but I have more of their products than any other companies (with the exception of Spektrum receivers) and never had a dud item or felt stitched by short comings. |
08-19-2010, 04:58 AM | #14 |
What is the castlelink for? Will it work with my ESC? Is this one better or does it need the link also? I know more questions. http://www.ckrccrawlers.com/castle-c...or-p-2231.html |
08-19-2010, 05:31 AM | #15 |
Firstly, woah, that is huge for a BEC. That's a Sidewinder ESC case. A 20 amp BECV would be nice, but size and weight would make that impractical for a 2.2 crawler. For a single servo application, the Castle Creations 10a BEC is all you need. The Castlelink is a little device that is receiver plug one end and mini USB the other and lets you access all the adjustments on all Castle ESC's (except the old Mamba Max, it has a mini USB in the side of it's case) and BEC's by hooking them up to your pc and running the Castle software. The 10a BEC needs it's output voltage adjusted (to 6v) to work well with most basic to intermediate servos. |
08-19-2010, 06:39 AM | #16 |
Would the castlelink work with my ESC? I have a Dura Trax ESC in the original post above.
08-19-2010, 06:42 AM | #17 |
No. Only Castle ESCs.
08-19-2010, 10:51 AM | #18 |
Is there a ESC that i dont need a BEC? The ESC i just bought will not work with any BEC's i can find. I dont want to buy a BEC and a cutoff that dont work with my ESC, when i can just get a better ESC. Thanks .
08-19-2010, 01:48 PM | #19 |
Holmes hobbies torquemaster. Has the largest internal bec to date
09-26-2010, 05:59 PM | #20 |
I talked to CKRC and they said I can use the Castle Creations 10amp Bec with the ESC that I have. Bought it - Tried it - Presto no glitch. Just thought you might want to know that you dont need a Castle Creations ESC for it to work.
