10-24-2010, 06:23 PM | #1 |
Quarry Creeper Join Date: Aug 2009 Location: here
| Mutant's Halfbreed This is my halfbreed I've been tooling around with. The Goodies: Loaded Creeper axles GC-1 Chassis Axial tranny DNA Dig Revo pushrods for lower links DNA beadlocks HB rovers DX3E Rooster Integy 55t Problems: In my excitement to test it out I broke off a tab on the axle for one of the upper links and lost a drive shaft. Not even 5 seconds into it's first run. Now I need a four link plate for the rear and probably a steel drive shaft for the rear too. I made up the plastic covers for the sides and top because my local crawling spot is the banks of the local river and there is fishing line everywhere. My mini always ended up tangled in some. |
10-24-2010, 07:51 PM | #2 |
Quarry Creeper Join Date: Jul 2010 Location: QLD, AUS
Traxxas Shaft's RMDesignsWorks Rear 4-link plate |
10-24-2010, 08:16 PM | #3 |
Had the traxxas shafts on the back. I got bound up from the start and twisted it off. I will check out the rear 4 link plate, thanks. |
10-24-2010, 08:32 PM | #4 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
the tab broke off cuz it wasnt tied to the other tab...the tabs need support between them. My new Creeper Link rear axle plates are a couple weeks out..Ill post up when they are ready. |
10-24-2010, 09:05 PM | #5 |
| I knew that it would happen, but I didn't think so quickly. I just finally got it drivable and wanted to see how it worked. I should have been more patient and made a spacer for the tabs.
10-24-2010, 09:33 PM | #6 |
RCC Addict Join Date: Aug 2005 Location: Naoma, WV
After you get a new housing to replace that, you may want to check out how RMDW tied his upper and lower link mount tabs together on the front and rear. I'm thinking I may tie mine in before I even run it. Been reading about more than a few broken tabs lately.
10-25-2010, 06:31 PM | #7 |
Rock Crawler Join Date: Feb 2010 Location: eugene
another option also for a 4 link plate if you want it up and runing sooner (if you where thinking of rmds plate) is ckrc or do what i did. i drilled a strc axial servo/battery tray to work on mine... |
10-25-2010, 09:15 PM | #8 |
Copy Cat!!!!
10-25-2010, 09:21 PM | #9 |
I just need to find those other sources. |
10-25-2010, 09:24 PM | #10 |
so what since I put the info in several spots its research?
10-25-2010, 09:28 PM | #11 |
10-25-2010, 09:33 PM | #12 |
10-25-2010, 10:08 PM | #13 |
10-25-2010, 10:31 PM | #14 |
A's and L's?
10-26-2010, 04:55 AM | #15 |
Ax----Losi
10-27-2010, 10:55 AM | #16 |
AH I'm away for two days and my thread got hyjacked!!! Oh well. I have some aluminum in 1/8" and 1/4" thickness. I think I'll try to fab something up out of that. I do like the plate using the RPM servo posts. Can anyone reccomend a decent low budget servo? I have two HiTech 645 but I stole the one for my mini and the other is being used for the dig. I'm still unsure of getting any from TowerPro. |
10-27-2010, 01:50 PM | #17 |
Pebble Pounder Join Date: Jan 2009 Location: San Mateo
10-29-2010, 07:33 PM | #18 | |
And we didnt hijack your thread,,,,we used it for smack talk....thats legal. Now,,downloading 12 pics of someone else's rig,,,HIJACK! | |
10-29-2010, 11:07 PM | #19 |
I know I'm not going to get much out of a cheap servo but right now I can't justify to my wife spending $100+ on a servo. Especialy with having several RC projects to fund right now.
10-29-2010, 11:50 PM | #20 |
Rock Crawler Join Date: Mar 2008 Location: Grand Rapids
the ckrc wiggle is about 40 bucks and 195 in/oz dont know how well they hold up but good torque for the money
