12-23-2010, 06:59 AM | #1 |
Newbie Join Date: Mar 2010 Location: everywhere
| Will this battery fit in the tray?
Just ordered a venom creeper kit and a rooster with a 55t and I'm wondering what the dimensions of the battery tray are? Will this battery fit in the tray http://www.hobbyking.com/hobbyking/s...dProduct=11938 ? and what run time do you think I can get out of it? Thanks |
12-23-2010, 07:51 AM | #2 |
I can't find the dimensions of the battery tray anywhere?
12-23-2010, 08:08 AM | #3 |
RCC Addict Join Date: Apr 2010 Location: Ringwood
the tray is a standed battery look for like a 6 cell flat pack and thats what will fit
12-23-2010, 08:32 AM | #4 |
Rock Crawler Join Date: Feb 2010 Location: eugene
Last edited by lazynocturnal; 12-23-2010 at 11:39 PM. Reason: misread post and gave wrong info |
12-23-2010, 02:05 PM | #5 |
Does anyone have a battery tray that they can measure?
12-23-2010, 03:59 PM | #6 |
Pebble Pounder Join Date: May 2010 Location: Indianapolis
Don't use the battery tray. problem solved. Seriously. read through "on the Creeper wagon" posted by rmdesignworks in the venom section (this section). It's several pages long, but everything you need to know is on the first couple posts by rmdesignworks. |
12-23-2010, 04:16 PM | #7 |
RCC Addict Join Date: Sep 2010 Location: Malta, NY
you can read that but the thing you want to read before you biuld your creeper id RMDW's T&T thread. that will give you all the tips that and tricks that you should and or need to do to make the venom creeper perform like a chanpion.
12-23-2010, 11:22 PM | #8 |
i found the pieces of my stock battery today and made some measurements. the measurements i copied and pasted were from the battery you put in the link. sorry about that, i had just woke up and misread your post before i went to work....now that im awake and reread it.... come on guys, the guy asked a question if a battery would fit in the battery tray. we dont know if hes the kind of guy that just wants to build a crawler out of the box to run it around his back yard or going to build a comp rig. so lets answer his question without telling him to get rid of it or go read some thread..... done with my rant, and back to the original question. the size of the battery is big. it will "squeeze" in width wise. now length wise it is about 6mm to long...as theres some plastic nubs that are part way into the battery tray that the battery will rub on. so my answer is going to be no. i looked on that same site and found some alternative choices around the same price... http://www.hobbyking.com/hobbyking/s...dProduct=14976 http://www.hobbyking.com/hobbyking/s...dProduct=16201 http://www.hobbyking.com/hobbyking/s...idProduct=9509 now the run time you may see with these pack may be around 2+ hours (depending on how you run your creeper). i ran a 4000mah 2s lipo when i first got my creeper and was running 2+ hours on it.... |
12-24-2010, 09:09 AM | #9 | |
Quarry Creeper Join Date: Dec 2010 Location: Phelan California
Im running a 2000mah lipo and get about a hour out of it and 2 5000mah 7.2v stick packs that give about 1.5 hours each. plenty of run time for me to get bored but then again most of my running has been just in the back yard so I hope to do better when im doing less full throttle stuff | |
