01-07-2011, 04:21 PM | #1 |
Newbie Join Date: May 2007 Location: concord
| Creeper trans binding
I just pick up a venom creeper for my daughter and started building yesterday. I built the trans and it binds up at about 180 degrees of rotation. You can force it past that point by hand but once you get back to that spot it binds again. I took the trans a part at least 6 times to check if I put anything in wrong but its all built right. The upper trans shaft has so slop in it with it installed in the case. The lower shaft fits snug. With the back cover off the gears spin with no bind but as soon as the cover is bolted on it binds. Any ideas?
01-07-2011, 04:41 PM | #2 |
RCC Addict Join Date: Sep 2010 Location: Malta, NY
check to see if you have any dirt or dabre stuck in between one of the teeth of the gears or even a little bit of plastic in there from the mounlding prossecess
01-07-2011, 04:50 PM | #3 |
Ive look at all the gears and all clean. I just put a motor in it and seems to be ok but wont really know till its all together. Thanks for reply
01-07-2011, 05:02 PM | #4 |
your welcome and be sure to post picks of it out have fun on the rocks
01-07-2011, 05:07 PM | #5 |
Will do! Im hopping to have it done by Sunday. Its my daughter B day present and her B day is Wednesday so it should be a runner by than.
01-07-2011, 05:12 PM | #6 |
cool cool tell her i said happy b day
