Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Venom Creeper
Thread: motor gears not turning
Old 02-09-2011, 05:50 PM   #1
Default motor gears not turning
hello i just put together my motor box with all the gears in it and its verry hard to turn by hand is it sopost to be like that or what please respond quick.their just really hard to turn.
Stright up is offline   Reply With Quote
Old 02-09-2011, 06:23 PM   #2
is the motor in or out when your turning the gears?
freakofnature is offline   Reply With Quote
Old 02-09-2011, 06:46 PM   #3
yes its nothing out of the ordinary, unless youve got gorilla hands you cannot turn the trans by hand. no worries finsh your build and let the motor break it in. dont forget your grease, dont be shy with it either.
liquidkool is offline   Reply With Quote
Old 02-09-2011, 07:04 PM   #4
Default thanks
hey thanks guys and every things fine..
Old 02-17-2011, 10:59 PM   #5
Exclamation what size
what size is the allen wrench thats goes in the axle shaft to hold the pin in???
Old 02-17-2011, 11:23 PM   #6
i think its a 1.5mm
lazynocturnal is offline   Reply With Quote
Old 02-18-2011, 06:43 PM   #7
i oreder a 2.5mm what it said on the bag and its hugeeee not the right one pisses me off that an allen wrench is stoping my build
Old 02-18-2011, 06:45 PM   #8
Unless the gear mesh is too tight????????? Pinion to Spur should have just a smidge of play,,,thickness of a piece of paper to set the mesh.
rmdesignworks is offline   Reply With Quote
