02-10-2011, 05:29 PM | #1 |
Quarry Creeper Join Date: Dec 2010 Location: lakeville Mn
| drive shaft angle?
My drive shafts seem to be at a big angle where it connects to the small shaft coming out of the axle. Instead of both of them being in more of a straight line to the tranny like some others I've seen. The shaft coming out of the axles seem to point downward, is this right? Seems like it should point up a little more. If I compress the springs and lower the body you can see that the front axle does not point towards the tranny it points below it. The rear looks the same way. Last edited by mwscooters; 02-10-2011 at 05:36 PM. |
02-10-2011, 05:31 PM | #2 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
my front axle/driveshaft is like that to keep the castor at a decent angle, i'd take off the driveshaft and max out the angle and rotate it by hand, then you can see its "max" angle, just make sure its the same or less when installed and it should be good to go. shorten your lowers, or lengthen your uppers to correct it if its a concern. |
02-10-2011, 05:37 PM | #3 |
Thats not really a bad angle. I've seen allot worse. Like stated above, longer uppers or shorter lowers will fix it. Can you get clockable C's to fit? That'd be ideal to keep the caster in check. |
02-10-2011, 05:39 PM | #4 | |
02-10-2011, 05:41 PM | #5 | |
you could also look into longer or shorter rod ends, then you dont have to worry about cutting your links | |
02-10-2011, 05:41 PM | #6 |
02-10-2011, 05:43 PM | #7 |
02-10-2011, 06:02 PM | #8 |
Pebble Pounder Join Date: Nov 2009 Location: joliet
you could also use a couple of spare nuts on the uppers or drill a new 1/8in hole, closer to the front of the chassis. trust me it wont hurt--- my stock chassis looks like swsis cheese from all my mods
02-10-2011, 06:47 PM | #9 |
Quarry Creeper Join Date: Dec 2010 Location: Phelan California
looks pretty close to my angle in front. In rear I lengthened the upper link a bit and made it straighter but in front there is not much you can do with out effecting the caster angle for the knuckles. to much or to little angle and you wont steer correctly but I have yet to experiment on the crawler on that yet. if it doesn't bind up I don't think it will be a big issue
02-10-2011, 06:52 PM | #10 | |
02-10-2011, 06:52 PM | #11 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
the easiest way to rotate the front axle so the pinion angle rises is to move the lower links to the outside of the link tabs but install a spacer or rod end ball in between the tabs to support them, dont just screw the links to the tabs and cause them to squeeze together. The rotate the lower links so the bends are actually horizontal and the front bend is turned inward to allow for more tire clearance.
02-11-2011, 08:44 AM | #12 | |
02-11-2011, 09:08 AM | #13 | |
RCC Addict Join Date: Apr 2010 Location: Ringwood
02-11-2011, 10:28 AM | #14 |
02-11-2011, 11:02 AM | #15 |
| your c-hubs are on correctly they only appear backward because of your axle is clocked to the back.................lengthen your uppers1/4" will make a big difference. |
02-11-2011, 11:42 AM | #16 |
| Thanks for the post, I'm glad that you let me know they were on right. I was starting to think they were wrong.
