02-27-2011, 03:43 PM | #1 |
Newbie Join Date: Jul 2010 Location: Coast
| Venom transmission gears TROUBLE
Hey guys! Is anyone else having trouble with keeping the transmission gears alive? Now, I know that I'm running a hard setup but my buddy with an axial has the same setup. I'm running a 27t hpi saturn that was a take out of my wheely king with a 7 cell battery and a novak rooster crawler. Just wondering if anyone else has had problems. I do drive it kinda hard in the sand, but It gets it alot easier in the rocks. My only problem has been with the transmission, and breaking spider gears. Other than that I love this thing and have had it for a year.
02-27-2011, 03:48 PM | #2 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
well the 27T is kinda wild , but you did'nt say what kind of trouble with the tranny. if your eating up the spur gear its probally the mesh. |
02-27-2011, 06:39 PM | #3 |
The spur gear was in good shape off the pinion side, its all of the other gears. I'm gonna switch to either a 45t or 35t hand wound.
02-27-2011, 06:46 PM | #4 |
Rock Crawler Join Date: May 2009 Location: branchville
im running a integy 35t in mine with no problems |
02-27-2011, 06:52 PM | #5 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
If your running it in the sand and dont have the Trans plug you could be getting dirt and sand in there. My suggestion would be tear the trans down and the axles, and clean and GREASE the hell outta it, make or buy the Trans plug to keep dirt out! also check your gear mesh is good. and drive axles, make sure everything is WELL greased, it never hurts to over grease things. Iv had my creeper for a while now and never had a problem. previous owner didnt grease things well and it sounded hard and sluggish when i got it, tore everything down re greased it and never had a problem since.
02-28-2011, 09:27 PM | #6 |
Newbie Join Date: Mar 2009 Location: mcminnville
iv had my creeper for about two years and been running novak goat system 18.5 13 pinion list to big to mention and iv gone through about three tranny gear sets and three housings so there is a slight problem with the gears but what iv came to realize is that its not the gears its the tran housing the pins get slop in it and then the gears go out so im trying to get some one to make a aluminum housing and gears but its to much money and venom will not give me the specs on the tranny so thats my two cents
03-05-2011, 07:46 PM | #7 |
Thanks guys! Yeah Burner, thats what is happening to mine. I have a plug and everything is keep well greased and clean. Maybe an axial trans is in my future.
03-17-2011, 09:13 AM | #8 |
Newbie Join Date: May 2010 Location: TORONTO
Wow it happened to me a couple days ago. I found very big noise from my rig while I was climbing on the rocks. After I put my ears close to my rig I figured it out its from tranny. Then I tear it apart and found my spur gear is worn out. I ordered 3 of them for backup.
03-17-2011, 01:06 PM | #9 |
Newbie Join Date: Mar 2011 Location: Akron-Canton, Ohio
My friend runs a Creeper and had trouble with his as well, the thin aluminum part on the front of the tranny where the motor mounts up wouldnt let the motor stay tight and would work its way out of mesh and wad up. He ended up taking that piece out and hasnt had trouble since. The lower left piece is the part Im talking about. |
