04-04-2011, 10:18 AM | #1 |
Rock Stacker Join Date: Dec 2010 Location: Ontario Canada
| BEC question
Well I'm just starting out with crawling. Just got my venom in today. I have been reading on here that I should get a bec. I wish someone would have said that I had to get one not that I should get one. I got a cheap duratrax speed controler shipped with my venom to start with and noticed that most speed controllers do not have a bec on them. At least there are no extra wires to power my receiver. Now I have to wait to look around to find a good one and figure out how to intall one. I guess I have to put my build on hold for a while now and do more reading. Oh ya the duratrax I got was the 1059.
04-04-2011, 10:59 AM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: Phelan California
you need the wires that go from esc to the rx, it usually looks like a servo extension just bring what you have to the hobby shop and im sure they can find the wires you need for a couple bucks
04-04-2011, 11:11 AM | #3 |
I think I got it figured out. I will buy a bec though. Time for more shopping. Lots to choose from. Hope I don't mess this up now.
04-04-2011, 11:37 AM | #4 |
Rock Crawler Join Date: May 2010 Location: Albuquerque
Check out rmdw's t's & t's. . . A lot of good info there and it shows exactly how to wire it up then check out my build thread and look at the last page I have a cool jumper that makes it easy to wire it up
04-04-2011, 12:17 PM | #5 |
castle bec and programming link |
04-04-2011, 03:58 PM | #6 |
04-04-2011, 04:27 PM | #7 |
| The castle link allows you to adjust the voltage output of your BEC. they come stock at 5.2v output but if your servo will take it you can usually crank it to 7v on 3cell lipo
04-04-2011, 04:36 PM | #8 |
RCC Addict Join Date: Sep 2010 Location: Malta, NY
hey chappy, im just woundering do you know how high i can go up to on my servo. i have a 7955 tg hitec servo and i want to be able to set it at 6v but if i can i ould like to set it at 7v. do you know how high i can go with that?
04-04-2011, 05:25 PM | #9 | |
I actually run it @ 6.5VDC, but I realize I "may" shorten it's life a bit. You can set it to whatever you want, but exceeding the 6.0VDC input will shorten it's life. | |
04-04-2011, 05:38 PM | #10 | |
Rock Stacker Join Date: May 2010 Location: Sydney/Australia
Your crawler will still work, you just may be lacking in the steering strength without running a more powerful bec, but it all depends if your servo is powerfull enough anyway. hope that helps | |
04-04-2011, 06:59 PM | #11 | |
You get an idea you need an external BEC when you load the steering and the rig quits working. You usually see the RX lights go off until you unload the front wheels. This is what I found, adding a CC BEC resolved that issue. If you're just having fun, maybe you can deal with the occasional issue. If you're comping, it becomes a major deal that requires you to "touch" your rig which adds up points quickly. | |
04-04-2011, 07:03 PM | #12 |
| +1 . . . . i have a hitec 7954SH which is rated at 7.4v max . . . so when i go 3cell i will program my BEC at 7 or 7.4v which should get me in the neighborhood of the rated 403oz. of torque.
04-04-2011, 07:13 PM | #13 |
Thanks for all the reply's guys. I guess when I'm done building I will try it out and see how it works first and see if I need one. I was thinking that my speed controller did not have a bec because there was no power wire to attach to my receiver. I'm use to the tamiya speed controllers that have a seperate wire for power. Also I did not think there were going to be so many small screws building this thing. What a pain. Well the tires are the worst. Has no problems with the tranny like others said they had. Thanks again guys. |
04-04-2011, 08:42 PM | #14 |
you made sure to install the motor before you mounted the trans to the chassis right?
04-05-2011, 03:06 AM | #15 |
04-05-2011, 05:11 AM | #16 |
Pebble Pounder Join Date: Nov 2010 Location: Mesa
I didnt see it mentioned but if you decide on a Castle Bec and purchase from Holmes Hobbies he will pre program it for you to what ever voltage you like. That way you dont have to get a castle link for one adjustment. I got mine programed for 6v and love it. Holmes shipping is way fast too!
04-05-2011, 02:32 PM | #17 | |
Newbie Join Date: Oct 2008 Location: The Granite State
Damn, wish I had known this. Now I need to find a local with a castle link. I bought mine from the LHS. | |
04-05-2011, 03:27 PM | #18 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
I'VE GOT 2 BEC's TO GET SET UP AND MY LHS DOES'NT DO IT ,THEY WANT TO SELL THE LINK BUT I CANT SEE THE $28.00 RIGHT NOW.
04-05-2011, 05:35 PM | #19 |
