04-05-2011, 07:08 PM | #1 |
Newbie Join Date: Jan 2011 Location: Gainesville
| creeper locker question
I love my creeper just don't like the manual locking diffs. I have had nothing but trouble with them first they kept slipping out of being locked so I glued the switch into the locked position then while I was crawling I heard something snap and it came unlocked and I couldn't get it to lock back. I took the diff apart and found that 2 of the 3 pins on the red locker r bent idk if that is the problem. I am wondering is there anyway to permitely lock the diffs or is there another whole diff I can get that will work with fit and work in the stock axle case or is the a whole axle set case diff everything that will work with the stock shock and suspension arm mounts. Thanks to anyone who can give any help.
04-05-2011, 07:17 PM | #2 |
Newbie Join Date: Sep 2008 Location: Kyle TX
you can get a set of fml lockers or there are many different ways to lock them in the tips and tricks thread
04-05-2011, 08:05 PM | #3 |
Rock Crawler Join Date: May 2010 Location: CRAWlORADO
rmdesignworks makes a steel linchon locker steel on steel the way to go |
04-05-2011, 08:13 PM | #4 |
Rock Crawler Join Date: May 2010 Location: Albuquerque
04-05-2011, 08:15 PM | #5 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
as far as I know the AX10 lockers fit aswell. (I will be trying this in a few day's, getting some creeper axles from a friend, and have 3racing AX10 lockers to go in) |
04-05-2011, 08:32 PM | #6 |
04-05-2011, 08:46 PM | #7 | ||
Rock Crawler Join Date: Feb 2010 Location: eugene
theres also flm aluminum lockers. good luck finding these. last i knew rcbros had them in stock. then rmdw makes "lincoln lockers" which are a welded set spyder gears... | ||
04-05-2011, 08:48 PM | #8 |
04-09-2011, 01:30 AM | #9 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
My Paradox Lincoln Lockers are all steel and welded....true welded steel lockers....not epoxied....and are guaranteed for life.
04-09-2011, 07:48 AM | #10 |
05-05-2011, 02:21 AM | #11 |
Rock Stacker Join Date: Jul 2004
| hmmm
JB WELD... done
05-05-2011, 07:49 PM | #12 |
Pebble Pounder Join Date: Apr 2010 Location: Canada
