04-28-2011, 04:27 PM | #1 |
Newbie Join Date: Feb 2011 Location: Monroe
| Transmission Locked
Ok, I have a new problem. For some reason, the tranny is locked up. I give it throttle, and you can see the drive shafts try to move, but they don't. I disconnected them from the front and rear diffs, and it still won't turn. Wheels/axles turn fine while disconnected from the drive shafts. Any ideas before I start tearing into the tranny??
04-28-2011, 04:33 PM | #2 |
Rock Crawler Join Date: May 2010 Location: Albuquerque
Try pulling your inspection cover off of the back of the tranny and get a flashlight and see if you can't see anything like stripped gears or whatnot. If you don't see anything than its a possibility your bearings siezed up. Either way the trans will have to come out. Hope this helps Chappy |
04-28-2011, 04:38 PM | #3 |
Quarry Creeper Join Date: Dec 2010 Location: Phelan California
ya what he said lol but Id pull your motor and make sure it spins also. mine did that turned out my pinon moved and the set screw was digging in to the gear
04-28-2011, 06:49 PM | #4 |
Newbie Join Date: May 2010 Location: TORONTO
It happened to me twice caused by motor pinon moved. Just make sure the motor screws are tight and redo gear mash again and it's done.
04-28-2011, 06:56 PM | #5 |
I think I found the problem: This is the inside of the DIG unit. Now to see where that screw came from! |
04-28-2011, 08:22 PM | #6 |
Rock Crawler Join Date: May 2010 Location: CRAWlORADO
04-28-2011, 11:56 PM | #7 |
Rock Crawler Join Date: Feb 2010 Location: eugene
judging by the length of that screw, im thinking if you bought a safari, it maybe a motor mount screw. possible that when it was being built the person could have droped it the tranny when installing the motor. instead of fishing it out they left it in there...im not a fan of rtrs...just found that my associated b4.1 rtr was missing 3 screws that hold on the motor plate. one, ok but 3 no...either they werent installed or were left loose...
04-29-2011, 03:37 AM | #8 |
Yep, it was a Safari, so it was already built. Must have been in there from the factory. There were no screws missing anywhere that I could see, so it's bonus!
04-29-2011, 05:27 AM | #9 |
Oh, forgot to mention one important thing...when the driveline locked up, it caused the ESC to smoke! Couldn't handle the overload in current I guess. But as usual, Venom customer service is great and they are sending me another one!! |
06-14-2011, 08:58 PM | #10 |
Newbie Join Date: Jul 2010 Location: On a Mountain
same thing happened to mine. 20 mins out on the rock pile and i heard some noises. had a screw in the tray that chewed up everything. theres a gear that has 4 screws that holds it on. looks like one of yours came loose too.
06-18-2011, 05:43 PM | #11 |
Rock Crawler Join Date: Mar 2011 Location: hampton
my safari had 2 screws just floating around in the tranny
06-19-2011, 01:27 PM | #12 |
Newbie Join Date: Mar 2011 Location: wisconsin rapids
