10-08-2011, 09:31 PM | #1 |
Pebble Pounder Join Date: Jun 2011 Location: Port Charlotte
| Pinion Size
Hi, just wanted to know what size pinion gears everybody uses with the stock spur gear, most and least number of teeth. Thanks |
10-09-2011, 12:34 AM | #2 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
19tooth on 55t motor...3S lipo...good wheel speed...loads of torque...40.8:1 final gear ratio. Check the gear ratio chart in my tips thread |
10-11-2011, 07:19 AM | #3 |
Thanks, that's the setup I'm running now. It seems like the 19t pinion is the max you should use with the stock spur gear. |
10-11-2011, 03:11 PM | #4 |
RCC Addict Join Date: Sep 2010 Location: Malta, NY
running a 19T on a 30turn holmes hobbies motor on a 3cell 40s lipo. LOTS of wheel speed and gobbles of torgue |
