10-23-2011, 08:55 PM | #1 |
Pebble Pounder Join Date: Jun 2011 Location: Port Charlotte
| PICS OF MY CREEPERFinall
Finally tooks some pics of my Creeper today and thought I'd post them.
10-23-2011, 09:43 PM | #2 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
kudos on the use of the double chassis' for the bodiless affect....roll your front axle back a bit though..by the BTL I can see that you are running negative castor...positive is better for crawlers
10-27-2011, 03:59 PM | #3 |
Thanks, I moved the upper arms back 1/8 in. I also did some chopping to the frame and changed the color and how the side panel are attached. Here's a list of my upgrades - RMD BTA Steering package & pin-lox Aluminum lockers Wheel extenders Rover White dots Novak 45T motor with 19t pinion Novak Rooster DSM receiver / controller 15 oz. of weight in each tire Aluminum servo horn HR 1 piece rear axles Front aluminum C-hubs Hitec 7955 servo CKRC Stage 2 Last edited by remmuh; 10-29-2011 at 01:35 PM. |
10-27-2011, 06:46 PM | #4 |
RCC Addict Join Date: Sep 2010 Location: Malta, NY
i like that setup. one thing i would think about is taking some weight out of your rear tires. im running 8oz in my fronts and none in the back (the wheels weight in at 8oz per so there 16oz in the front and 8oz in the rear) |
10-28-2011, 10:41 AM | #5 |
Quarry Creeper Join Date: Jun 2010 Location: Ireland
I'm intrigued by your boydless tvp design. Could you please post a close-up pic?
10-28-2011, 12:36 PM | #6 |
Thanks VCD. I removed 5 oz. from both rear tires. I won't be able to test my VC today as it's raining. Maxx Savage here's some pics for you - Last edited by remmuh; 10-29-2011 at 01:43 PM. |
10-28-2011, 01:01 PM | #7 |
Some more -
10-28-2011, 08:15 PM | #8 |
i have to say, this is a very interesting biuld with the twin creeper stock chassis |
10-29-2011, 11:44 AM | #9 |
Close-ups
10-29-2011, 12:20 PM | #10 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
VERY INTERESTING , I'VE GOT 4 STOCK CREEPER CHASSIS' AND NEVER THOUGHT OF A USE FOR THEM. DEFINATELY THINKING OUT OF THE BOX. |
10-29-2011, 01:50 PM | #11 |
Another from the back -
10-29-2011, 09:31 PM | #12 |
looks good |
10-30-2011, 08:37 AM | #13 |
Thanks!
10-30-2011, 03:41 PM | #14 |
Pebble Pounder Join Date: Dec 2010 Location: Elk Grove
If I may say so myself, that's too much articulation if you plan on comping it. Good looking rig though |
11-02-2011, 07:24 PM | #15 | |
RCC Addict Join Date: Apr 2010 Location: Ringwood
i personally like a little more like 6" but its usually around 5.5" | |
11-04-2011, 06:02 PM | #16 |
| Made some changes - added upper and rear body panels replaced screws with button heads moved receiver to top of tranny removed 5 ounces of weight from each rear tire ( thanks VCD ) moved upper front control arms back 1/8 of a inch to improve camber angle ( thanks RMD ) |
11-04-2011, 07:41 PM | #17 |
looking good , i say thou what is the ground clearance on that rig u got?
11-04-2011, 07:49 PM | #18 |
Thanks! ground clearance is 3.25 inches.
11-04-2011, 08:43 PM | #19 |
Pebble Pounder Join Date: Sep 2008 Location: philly
looks great, great idea, i might just steal it....lol
11-04-2011, 09:49 PM | #20 |
one more pic -
