03-03-2012, 07:26 PM | #1 |
Newbie Join Date: Jan 2012 Location: in the rocks
| Reds Creeper
Spektrum DX3E Venom 55t motor Venom Lockouts in front and rear MG946R Metal Gear Servo Castle Sidewinder SV2 ESC cut down battery tray cut all the short knobs off tires relocated shocks skid plate made out of a washer fluid bottle This is my Creeper. If you see anything that I can change please let me know. Its my first crawler. Im not running any comps just bashing in the backyard. Thanks Red |
03-03-2012, 08:01 PM | #2 |
Pebble Pounder Join Date: Feb 2012 Location: Sedro-Woolley,WA
| Re: Reds Creeper
looking like a good start man |
03-03-2012, 08:16 PM | #3 |
| Re: Reds Creeper
Thanks man. I also got weight in the front wheels with holes drilled in all 4 rims.
03-04-2012, 05:34 AM | #4 |
Newbie Join Date: Jan 2011 Location: Israel
| Re: Reds Creeper
get the internal spring out.
03-04-2012, 08:31 AM | #5 |
Quarry Creeper Join Date: Jan 2011 Location: murrieta
Rigs lookin good bro. I like that skid plate. Sent from my iPhone 4 using Tapatalk |
03-04-2012, 08:18 PM | #6 |
| Re: Reds Creeper |
03-04-2012, 08:21 PM | #7 |
| Re: Reds Creeper |
03-04-2012, 08:33 PM | #8 |
RCC Addict Join Date: Dec 2008 Location: pullin somebody else out of a mud hole
| Re: Reds Creeper
looks good so far red . only thing i worry about is the openings in the skid for the lower links restricting the movement .
03-04-2012, 09:26 PM | #9 |
| Re: Reds Creeper After I put it on I made sure they weren't rubbing or taking any of my movement away from me. It works pretty good. Mine came with the old type short skid plate so I had to try something. |
03-07-2012, 06:37 PM | #10 |
| Re: Reds Creeper This is my rear skid plate. |
03-07-2012, 06:43 PM | #11 |
| Re: Reds Creeper
I also have a problem when I stop going down hill it keeps rolling foward. Do I need to make changes to my esc (brake/drag brake) or just bump the trigger like im gona go in reverse? thanks |
03-08-2012, 01:27 AM | #12 |
If you hav'nt programmed the esc then the drag brake is set to off by default. You'll need to turn it on, I think there's 4 different setting for braking power on it.
03-18-2012, 11:07 AM | #13 |
| Re: Reds Creeper
Lokja good, I like the inverted cut battery tray idea. How did you support ur trans? Also posted some pics of my skid plate for ya. I also like the rear skid idea, I have to get one shaped up for mine. Seems to be wearing thinner then it should.
03-18-2012, 06:50 PM | #14 |
| Re: Reds Creeper My trans is only supported by the bolts on the bottom and on the side at the bottom, none at the top.
03-18-2012, 07:10 PM | #15 |
| Re: Reds Creeper This is my new skid plate I made out of a gojo hand soap bottle. Front view of new rear skid plate. Made out of the same thing as skid plate. Rear view Moved the rear links to the front of the axel. |
03-18-2012, 07:40 PM | #16 |
Great job on that new skid plate. Someday I may try my hand at making one like so.
Reds Creeper - Similar Threads | ||||
Creeper Crawler conversion Safari Creeper | Grumpster1980 | Venom Creeper | 25 | 02-24-2011 07:57 AM |
4 yellow scorpions and 2 reds found in Michigan!!! | ccampb04 | General Crawlers | 5 | 04-22-2006 06:44 PM |
