![]() | #1 |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
so i broke my pinion gear crawling last weekend, got some rock bounce air and caught an edge wrong, the ring gear is fine i just need another pinion gear, my LHS carries team associated, traxxas, hpi, ofna, and losi would i be able to use any pinion from another rc to use for this weekend because over night shipping is through the roof! if not i guess ill just sit out this weeks scale outing ![]() |
![]() | #2 | |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
| ![]() Quote:
![]() | #3 |
Already talked to venom got hooked up with a free set, just wondering if anything would work
![]() | #4 |
Rock Crawler Join Date: Nov 2011 Location: Paradise, ca
Thats good to hear how old is you safari
![]() | #5 |
Quarry Creeper Join Date: Jan 2011 Location: murrieta
![]() | #6 |
Well..I stood in a Hobby Town and looked for over an hour at pinion gears and ring gears for everything from Associated's to Tamiya's to X-ray's and nothing is close enough to be called a replacement...Axial pinions are close but the gear shoulder is wrong along with the depth of the gear...the shaft is also wrong but close. Axial ring gears are completely wrong due to the thickness and center bore and bolt pattern. In order to install different ring gears a custom spool or diff carrier is needed to accept multiple ring gears...then the gear lash has to be figured along with shim thicknesses and pressure angles.
Pinion gear | meshal | Team Losi Comp Crawler | 4 | 01-10-2012 03:09 PM |
what pinion gear? | miniguy | Axial SCX-10 | 2 | 04-17-2010 06:23 AM |
Pinion Gear | tecboy | Axial AX-10 Scorpion | 11 | 01-18-2010 08:44 PM |
