06-24-2009, 07:52 AM | #1 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
| Cable Bridges
I know there is no official rule but, what is the normal width (cable to cable) for a 2.2 cable bridge? (Such as those at Nationals etc)
06-27-2009, 10:43 PM | #2 |
I have only seen a couple, but all have been the width of a 2.2, right in the middle of the tire. |
06-27-2009, 10:48 PM | #3 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
Even though I understand the challenge of it all. Why in the heck is thier a cable bridge in RC crawling when you would never see it in real rock crawling? just curious is all.
06-27-2009, 11:05 PM | #4 |
06-28-2009, 12:59 AM | #5 |
They are there to be just another thing I have troubles getting over, through or around.... |
06-30-2009, 01:36 PM | #6 |
I wanna be Dave Join Date: Feb 2004 Location: on a Big Rock
| Dealing with man made obstacles is not my favorite part of ROCK crawling for the very reason this thread was started. At WCC I knew there would be cables, so I had some thicker hexs to deal with my narrow track width. I decided not to install them, and as you can see my truck barely fit on the cables. Last edited by Fishmaxx; 06-30-2009 at 03:25 PM. |
06-30-2009, 01:46 PM | #7 |
Rock Crawler Join Date: Nov 2008 Location: kansas city
persanaly i dont like the idea of having to roto-hammer all these beautiful rocks
06-30-2009, 02:53 PM | #8 |
I wanna be Dave Join Date: Mar 2008 Location: Pacific Ocean
| Pretty insignificant from an environmental perspective. You should see what the 1:1's were doing to the rocks. Or the rock climbers just down the road. 4 holes will not be noticed.
06-30-2009, 03:10 PM | #9 |
Keep Crawling in Crawling Join Date: Jan 2009 Location: Commerce City
The downfall I see to cable bridges are the widths they are built at. The rules state you can be 12.5" wide or you can be as narrow as you want. If a cable bridge is built to be centered on a Losi width rig then a berg with rig will have problems being centered and possibly not fit on the cables. I understand the reason a cable bridge is put into a course but I do not think it is a fair assesment of skill do the possible widths of a rig.
06-30-2009, 03:10 PM | #10 |
we ended up using 10" and it worked pretty good. I agree with the above that they should not be in rock crawling but, I was out voted. I think only maybe 3 trucks managed to get across the bridge without problems (Luckily I was 1). Even with the cables stretch tight, the wind would catch the trucks and get everything rocking. There needs to be a standard established if they are to be used in major comps. We ran into problems because 1 person would have a narrow Axial and then the next a wide Berg. The 10" worked because it was on the outside of the narrow and the inside of the wide. |
06-30-2009, 03:38 PM | #11 |
The course designer just needs to insure that the gates involved can still be progressed even if the rig falls off. The only penalties being more time or a gate penalty therefore giving a reward to those that are able to cross it without falling off. It would suck if your run ended because your righ did not fit on the cable bridge.
06-30-2009, 03:48 PM | #12 |
Ultimate RC Decals Join Date: Aug 2005 Location: San Antonio
one of our comps last year we set up two cable bridges, one was a tight bridge and the other we kept loose. the loose bridge was alot more difficult to get through. if you want it challenging try a loose bridge. cables were set to the width of the tires center to center. |
06-30-2009, 04:13 PM | #13 |
i see cable bridges as more of a spectator thrill than a challenge, certainly not necessary. do they belong in rock crawling? maybe not, but i think they're fun. here in vegas the only man made obstacle we've ever involved in a comp was an old burnt out mattress we found in the desert. |
07-01-2009, 10:22 AM | #14 | |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
When I set up cables, they are set at 8.5" mark based from a 10 1/8" wide truck. Narrower trucks can make the obstacle, along with some wider ones as well. The only time we had a problem is when Josh(carbonuts) was running the bullies(pre-release) and I think he was near the 9" width, which only allowed him 1/4" on each side.. | |
07-03-2009, 06:54 AM | #15 | |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
I think the whole cable bridge thing may become pretty difficult with the diversity of rig widths out there. SO who's width do you base the width on a losi? My super wide berg? or a axial? And how would this be fair to make a decision on width? The rules state a rig can be no wider then 12.5 inch and a gate can be no less then 16" so isnt a cable bridge braking the rules in some way? | |
