Go Back   RCCrawler Forums > Competitions and Events > WRCCA > WRCCA Rules
Thread: tire height?
Old 02-13-2011, 01:28 AM   #1
Default tire height?
whats the tallest tire allowed for 2.2 class? I see where people are cutting and enlarging some, i just want to know the max. thanks
dynamaxxed is offline   Reply With Quote
Old 02-13-2011, 01:40 AM   #2
▪ 2.3.3 - Vehicle is limited to 2.2 inch wheels/rims or smaller at the bead surface. Wheels may be modified provided
that the tire bead surface does not exceed 2.2 inches in diameter. With a tire mounted no exterior component of the
wheel including but not limited to the bead lock ring shall exceed 2.55". Tires may be modified from other sized tires
using only a pliable rubber but must not exceed a total uncompressed outer diameter of 6 inches.
Rogue is offline   Reply With Quote
Old 02-13-2011, 01:50 AM   #3
thanks, i just saw it. I guess I overlooked it first couple times
