Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > XTM Crawler
Thread: xtm crawler axle problems already?
Old 12-22-2008, 01:04 PM   #1
Default xtm crawler axle problems already?
so after waitin what seems to be forever..finally got my XTM crawler...
had plans for this one for a long time..decided not to turn it into a stick right away,instead wanted to try a 50/50 droop sprung using hpi super savage shocks and make my own tvp chassis to play with geometry a bit..well as usual i got off subject...got it up n runnin couple days ago playin round with the 4ws last night driving round my basement and noticed rear axle wasnt pushing
...short story..pretty sure i sheared the axle drive pin..thinking bout replacing it with a tool steel pin..will update when i have time to take it appart and see exactly what the probem is..just a bit disappointed got to admit..pretty sure i am gonna get in a bind somewhere in a comp and really dont like trying to finish a course in 2wd
gadge is offline   Reply With Quote
Old 12-25-2008, 04:11 PM   #2
I suspect you actually broke the end off the drive shaft (where the pin is held). A lot of us have done that.
Dynamic^Cipher is offline   Reply With Quote
Old 12-25-2008, 06:57 PM   #3
and the new weak link is..........
cluster gear! the smaller gear is pressed in to the larger one with apparently not enough interference between the two
i feel sorry for anybody that tries a brushless on this axle!!!
for now how do i fix this before sunday..the start of our local indoor season
my first thought is to tig weld but cant do that till monday at the earliest,but even that seems to be a real pain..idlers are on shafts with spacer sleeves..to much weld and it will bind
Old 01-01-2009, 11:22 AM   #4
quick picture of the weak link...for me at least
Old 01-03-2009, 03:04 AM   #5
JB weld may have held for a day or so.
Old 01-21-2009, 07:45 PM   #6
Default shitty axels
yeah i bought the xtm clrawler. and i used it for my second time second run 5 minutes in the dam axels snap. Running two integy 55 turn motors with 2 sidewinder 1/10th esc's with airtronics high powerd servo's. and for power two lipo 11.4 volt 1800 mah battery big power but the cheap axals blew outr does any one know of any if they make better stronger replacments?
bsneasy is offline   Reply With Quote
Old 01-21-2009, 07:49 PM   #7
contact Xtm there number is in the booklet for replacement i have been waiting about 13 days for replacements still dont have any
and yes there spose to be stronger
crawlman is offline   Reply With Quote
Old 01-22-2009, 04:16 AM   #8
fixed it myself!! thanks for info..if i have more gear related problems i will get those
hoping it was a fluke
Old 01-23-2009, 08:21 AM   #9
YOu fixed tha axel yourself???? let me know how you did it so i can get on the rocks thanks
Old 01-23-2009, 10:10 AM   #10
on a smooth steel surface..to keep flat staked the sides of the larger flat gear using a sharp center punch..
8 equally spaced pricks..about 1/8" from the i.d. on each side..alternating sides to prevent warping
this effectively reduced the inner diameter enough that i could re-pres the gears together ..hammering them is not an option..pressed!!
smooth jaw vise will work let me know if any issues
Old 01-24-2009, 12:01 AM   #11
what about your axels did yours break at the pin did you get replacements on those
Old 01-24-2009, 01:24 AM   #12
didnt even get to crawl over anything..
this was the first to go
Old 01-24-2009, 08:37 PM   #13
Did the axels break at the pin or just the gears?????
Old 01-25-2009, 02:08 AM   #14
no the axle pin hasnt broken yet
bit it did puke up an e clip**found it on basement floor
Old 01-26-2009, 01:19 PM   #15
did the small stripped gear (in the photo) brake off the big gear and is that the replacement gear behind it (leaning on that green shaft? do not understand what axle or gear you are talking about, i have a xtm crawler and idd not run it yet
krazikev is offline   Reply With Quote
Old 02-02-2009, 05:34 PM   #16
There are two weak spots found the gears as seen in the pics (i havent has those problems yet)
The solid axel with the pins on each end (Xtm has an upgrade part for it if your is one of the ones that came with these bad axels)
