Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > XTM Crawler
Thread: Xtm tuber
Old 01-13-2009, 02:30 AM   #1
Default Xtm tuber
got bored this weekend....
13" l x 5" h x 3 1/2"
now i just gotta put it back together
gadge is offline   Reply With Quote
Old 01-13-2009, 05:07 PM   #2
looks good man...cant wait to see it all together
TLT-ROCKER is offline   Reply With Quote
Old 01-14-2009, 11:39 PM   #3
Looks nice. I'd be worried about the strength of the link mounts though.
Dynamic^Cipher is offline   Reply With Quote
Old 01-16-2009, 03:59 PM   #4
dont worry DC..i am not done yet
i am waiting for the UPS dude right now
ordered a couple hundred steel bushings the other day to be used for
4 link mounts...shock mounts..radio tray
gonna have all of them mounted in double sheer..i am making triangulated sub assemblies for 4-link upper mounts
did a quick mock up of the chassis while waiting to see where exactly i wanted mounts and etc.
****camera on its last leg****
added a uhmw plastic skid..which will be notched and tapered later to move lower links inboard
lost some clearance and track width going with the axial narrow wheels ..so added wheel wideners..trying two different ones
got the track back to 15 1/2" with the narrower ones(front)
rear ended up too wide..16 1/2"..I'l keep them for another project
with the lower links "temp" stuck into body mount holes 4" approx
ended up with exactly 18" wheelbase..seems a little long but i like it
gonna loose a bit
the shocks are also gonna get moved to a more upright position in front
shocks are hpi super savage singles HUGE !!
have some internal springs also but not installed yet
thinking bout "free droop and winching down"
in pic still got almost an inch of droop
GOTTA GO UPS IS HERE!!!
Old 01-16-2009, 04:51 PM   #5
Bart bender's Avatar
That's sharp! I like it. You guys get yer axle shaft delema figured out? Sorry I havn't kept up with most of the XTM posts.
Bart bender is offline   Reply With Quote
Old 01-17-2009, 09:11 AM   #6
Im digging that chassis... did you use 3/16 tube or 1/8 solid rod?
jetboat is offline   Reply With Quote
Old 01-17-2009, 11:34 AM   #7
I was the one with the cluster gear problem..I fixed that myself
didnt do enough crawlin to break an axle yet
we dont run supers in the winter so i am ok for now
really want to clock my axles..but ill wait for them to break
that way half the work is done
Old 01-17-2009, 12:14 PM   #8
its 1/8" solid..use 5/32 also, i like the look of the smaller and yes its brazed..when done will be fully triangulated also!!
doesnt weigh much either..weight as pic(with thick body panels) 8.5oz!!
if anyone stops and figures it out 1/10 scale
1/8 rod=1 1/4 and the 5/32 = 1 1/2..
also it bends around a "correct" radius
ive been a pipe fitter/fabricaror in heavy industry for almost 20 yrs
also did a bunch of work on my friends Pro-Mod camaro
having bent thousands of feet of pipe and tubing having the wrong radius was driving me crazy
so much so ...that your gonna see a blue star here within a couple of days..shhhhno one looks here often
Old 01-21-2009, 12:48 PM   #9
what are u using for lower links? or did u just bend the stock ones ?
prozak is offline   Reply With Quote
Old 01-21-2009, 03:43 PM   #10
+1
I bet those are custom
just because of his job lol
I wish he would get on because he had the axel problem also I think
crawlman is offline   Reply With Quote
