Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: XTM X-Factor truck help?
Old 01-24-2009, 02:13 AM   #1
Default XTM X-Factor truck help?
I pick up a use x-factor truck and some of the parts are missing. The pull start rope on the 24.7 engine is tight when its pull and doesnt retract back. I try turning high speed needle clockwise and remove glow plug and unflooding the engine trick but still the rope are tight. Also i notice that the brake throttle setup is missing and if someone can find some pictures of the brake setup on the truck that would be very helpful as to what parts i am needing. I have some pictures of the truck. I would like to get this truck up and running any help would be great. Thanks.
xtm09 is offline   Reply With Quote
Old 02-14-2009, 08:31 AM   #2
Thumbs up sanford debary here fl
i have an xtm factor ill try to send pics to help u ,u could write back if u have problems
rican69m is offline   Reply With Quote
Old 02-14-2009, 05:56 PM   #3
Thumbs up sanford florida 17-92 bridge rock
xtm factor 2
Old 02-14-2009, 05:59 PM   #4
Old 02-14-2009, 06:00 PM   #5
Default sanford fl
Old 02-14-2009, 06:02 PM   #6
Old 02-14-2009, 06:02 PM   #7
Old 04-05-2009, 08:35 PM   #8
is it just me or does that front shock look severly bent.
dyecocker is offline   Reply With Quote
Old 04-09-2009, 07:09 AM   #9
Looks bent to me to, but i didnt have my v 8 today ....
rockeater is offline   Reply With Quote
Old 04-09-2009, 09:41 AM   #10
Thumbs up sanford fl rocks
shock not bent is the spring out of socket ,i took the cantalever off cut the ears off lower the frame ,if any body needs help ill be glad to help.
Old 04-10-2009, 09:39 AM   #11
My bad sorry about that...
I actually have this same truck but when i got it i converted it to electric, locked the axles and tranny, but sat for a yr now. i was thinking of either finishing to a crawer or making it nitro again. Question is how does it perfom being nitro. I mean suspesion and handling, not sure if i want to mess with nitro mainly is why i ask.
Old 04-11-2009, 07:28 PM   #12
If you need any nitro parts pm me i have everything including engine and tranny.
Im gonna use axles to make me a crawler i believe.
