| | #1 |
| Quarry Creeper Join Date: Jan 2004 Location: Ontario, Canada
| I just wanted to know where I could buy a set of X_Factor axels for a project in the making. Thanks, jugg_crawler |
| Sponsored Links | |
| | #2 |
| Rock Stacker Join Date: Jan 2004 Location: Morgantown
| You should be able to buy them at Hobbypeople.net and if you cant find them there I just saw a set on Ebay. Just go to Radio control-Trucks and type in X Factor and you will see them. I think they started at 40.00 Good luck, Shadow |
| | #3 |
| Newbie Join Date: Jan 2004
| for some reason i can't find them in the replacement parts. try ebay. |
| | #4 |
| Found them. Axle Shafts They are labeled as Xtm Gearbox - X-Factor, F/R & L/R and Xtm Gearbox - X-Factor, middle. Have no idea why they just aren't labled as replacement axle tubes. |
| | #5 |
| Thanks stumpy. jugg_crawler |
| | #6 |
| hey Stumpy what else do I need? jugg_crawler |
| | #7 |
| 4 Axle Shafts 4 Axle Couplers 4 Wheel Hubs 2 Ring Gears 2 Pinion Gears 2 Differentials or 2 Cup Style Differentials Are Ready Put Together For You Thats all i think. If the couplers don't come with set screws then your gonna have to find the dimensions. Also You need the ball bearings to. Thats all that i can think of. It would probably be easier to get a set off ebay though. |
| | #8 |
| Thanks and now that you saw that I I am in the middle of buying the two on there right now. jugg_crawler |
| | #9 |
| there might be acouple things im missing though so don't get mad. |
| | #10 |
| Don't worry. I am buying the axels off e-bay with the steering hubs for $144.00 so I am happy with that. jugg_crawler |
| Thread Tools | |
| Display Modes | |
