Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > XTM Crawler
Thread: What gears are pressed? Mine look solid
Old 11-19-2009, 09:27 PM   #1
Sometimes, I make things.
crazyorigin's Avatar
Default What gears are pressed? Mine look solid
I took the gearbox on my XTM X-Crawler axle apart today to look at maybe clocking the axles, and inspecting the gears. I didnt get it totaly apart due to not pressing out the pin in the axle shaft, but the gears look like solid steel gears in the gearboxes.
Are the new gears you can get on the link below new, 1pc gears? Which gear is it that is the issue? The gears in mine looked like they were all 1pc, i didnt clean all the grease off but they look beefy. Did they put upgraded gears in some of the newer kits? I have a yellow truck on the box, and i just picked this up a couple months ago.
globalservices.globalhobby.com
crazyorigin is offline   Reply With Quote
Old 11-19-2009, 10:01 PM   #2
You can still take the gears out without having to remove the axle pin. You should check it so that feel more secure, I have the yellow box and mine were pressed,so I called and got replacement gears for the axles.
minisaba is offline   Reply With Quote
Old 11-20-2009, 03:37 PM   #3
is it all of the gears or just one gear? If its one, which one? The only one i can think it may be is the one that has the big, and little gear together, but it didnt look like it had a seam in it to me.
Old 11-20-2009, 08:52 PM   #4
All the gears are the same. When you call for replacement they will send you all of them. Have fun.
Old 11-24-2009, 06:12 PM   #5
do the gears need to be welded to the shafts that go through them? i was expecting a 2 piece gear from how they were described in some posts.
Old 12-20-2009, 08:11 PM   #6
Little gear pressed into the big gear on ALL of them. Newer ones R just a tighter tollerence. Little Gear should need to B welded to the big gear, (Good Deep Weld), ground flat and Hole cleared for the shaft.
This will just about "Bullet-Proof" the drivetrain except for the axle shafts.
If the gears slip, the driveshafts will snap as well. It was a batch/botched job, they both had been over heated, making them brittle and subject to problems.
PlainOleDave is offline   Reply With Quote
Old 12-22-2009, 04:07 PM   #7
Awesome, thanks for that. That is the only place i can think of where they would be pressed. I was gonna sell this but i think i will build it and set it up. I'll get them yanked out and weld them up, thank you.
Old 01-07-2010, 12:55 PM   #8
Hey, How did you guys change the gears without taking the pin out from the end of the axel shaft. Can anyone put it down step by step please ? I am totally new at this and need to change my gears :(
i reached this far...pics below
Le0Heart is offline   Reply With Quote
