Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: Adapters?
Old 03-27-2004, 07:35 PM   #1
Default Adapters?
Where can I get a set of X-Factor to Maxx wheel adapters? Will I have to make them myself?
jugg_crawler
jugg_crawler is offline   Reply With Quote
Old 03-28-2004, 09:41 AM   #2
Default Re: Adapters?
hobbypeople.net
XTM sells them
they are actually Savage stub axles, etc.
DirkDigler is offline   Reply With Quote
Old 03-28-2004, 10:30 AM   #3
Thanks Dirk. What mods do they require to mount them?
jugg_crawler
Old 03-28-2004, 01:50 PM   #4
No mods needed. Take the steering knucles off and change the stub axles and put the knuckles back on. The stock stubs have a set screw in the end where the wheel nut goes on that holds the pin in place the ones in the adater kit does not. Thats it.
4XADICT is offline   Reply With Quote
Old 04-04-2004, 08:33 AM   #5
So on the new ones it doesn't require a wheel nut to hold the pin in or do you use the stock one?
jugg_crawler
Old 04-04-2004, 08:42 AM   #6
What are they listed under on hobbypeople.net? I couldn't find them on there even when I went through there twice.
jugg_crawler
Old 04-04-2004, 01:02 PM   #7
http://www.hobbypeople.net/gallery/146110.asp
Oh yeah, almost forgot. The pins are held in place by the drive hex just like a T-Maxx, Savage, or most others that use this type of drive. So be carefull when removeing the wheels after the swap because if the hex stays in the wheel the pin can fall out.
Old 04-04-2004, 02:22 PM   #8
I just use some red theadlock to keep the hexs and pins in place.
shadow is offline   Reply With Quote
Old 04-04-2004, 03:25 PM   #9
Thanks very much Shadow.
jugg_crawler
Old 11-07-2004, 12:28 PM   #10
If you use the savage stub axles do you use the x-factor bearings or the savage bearings or are they the same?
BakedMopar is offline   Reply With Quote
Old 11-07-2004, 09:20 PM   #11
I joined the Band!
The savage axles work with the stock bearing.Just did it this weekend
rubicon20032003 is offline   Reply With Quote
Old 11-09-2004, 03:56 PM   #12
The savage axles are right and left hand threaded which makes it easier for the nuts to spin off. I 'think' the xtm adapters are not right/left hand threaded. Could someone clarify this?
I have the xtm's and I have never had a wheel spin off on me, knock on wood!
cman_1500w is offline   Reply With Quote
Old 11-30-2004, 09:32 PM   #13
Ok I know i am going to catch a little FLAME on this, but are they sold in pairs or each??
I just got my x-factor and I am new to all this
harley_sr is offline   Reply With Quote
Old 02-23-2005, 01:18 PM   #14
Post T-Maxx adapters
Ok, I dont know what you are looking to do exactly but I would say its best to do something where you can use almost any wheel out there without switching axles. NEW ERA Models sells hex adapters for savage and t-maxx that just slide over the stock XTM axle. They run about 35.00 for all four plus shipping. neweramodels.com
Junior is offline   Reply With Quote
