Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: Bft tires on x factor??
Old 03-28-2004, 09:53 AM   #1
Default Bft tires on x factor??
Hello everyone as you can see I am new here and I am gonna be getting a x factor soon new...unless someone has a used they will sell me. So I was wondering if the associated BFT's will fit the x factor?? Thanks a lot!!!
Crawla is offline   Reply With Quote
Old 03-28-2004, 01:43 PM   #2
Default Re: Bft tires on x factor??
Yes they will. Get them, you won`t be sorry. They are a huge improvement over the stock X-F tires. They grip hard so you might want to get a weelie bar soon.
4XADICT is offline   Reply With Quote
Old 03-28-2004, 01:59 PM   #3
Ok, I have heard that they work better if you cut some of the tread the way you want it so the tire is flexible and it makes it so you can wrap it around the rim more . Well, I have seen pictures that people have done, but I havent seen any close up's of the tire tread after it is cut. Can someone show me how to cut it and where to cut it. I know there are a lot of posts on this but I need a straight forward explanation with some close up pics. Thanks!!!
Old 03-29-2004, 12:08 PM   #4
Did you see the home page? You can see some cut BFT's there.
DirkDigler is offline   Reply With Quote
Old 03-29-2004, 06:45 PM   #5
Hey, ya actually I did see some cut bft's there but I wanted some shots even closer then those ones and from the front and side. So if you could snap some pics of yours I would really really appreciate it.
Old 04-02-2004, 07:34 PM   #6
XFACTOR's Avatar
CRAWLA- u will have to buy the xtm 14mm hex axles though... as the stock X wheels have a pin fit
ryan
XFACTOR is offline   Reply With Quote
Old 04-02-2004, 08:19 PM   #7
Hey, thanks a lot, I was wondering about that. Can you give me a link online to where those would be?? And some rims that would fit with the bft's and the 14mm hex's.
Old 04-02-2004, 11:19 PM   #8
Here are the adapters http://www.hobbypeople.net/gallery/146110.asp
these come in pairs so get 2, or you can use these same parts for a Savage.
Here are the wheels I`m useing but you can use any standard T-Maxx,Savage, or MGT wheel.http://www.maximizerproducts.com/bead.html
Old 04-03-2004, 04:40 PM   #9
Hey man, thanks a lot!!!
