| | #1 |
| Quarry Creeper Join Date: Jan 2005 Location: Denver, CO
| hey, just joined cuz i want to get into rc crawling. anyway, i am looking into getting a X-Factor 2. don't try to get me to buy an electric truck because i won't. i've already sold all my electric stuff and only run nitro right now. my question is: i heard about a "slider clutch" and i'm curious as to what it is. i've read up on nitro crawlers and according to most people the reason they can't crawl as well is because the clutch's aren't suited to engaging and disengaging as much as crawling requires and they heat up and lose performance. this all makes perfect sence, i used to have the same problem with my nitro ST. does a "slider clutch" work differently? please help me understand it. also, would it be possible to build a custom clutch cooler. maybe passive with maybe a heatsink on the clutch, or active with a fan, or even water cooled? that seems like the best idea what do you guys think? thanks! |
| Sponsored Links | |
| | #2 |
| bump |
| | #3 |
| Quarry Creeper Join Date: Jan 2004 Location: Austalia
| You'd be better off buying a clod but seriously..what you need to do is buy some alloy clutch shoes, these wont burn out easy like the rubber/plastic ones...and tighten the slipper clutch right-up.. Although with any nitro truck..it will suck at crawling..you cant get the same control out of one liek you can in an electric truck.. So why don't you want an electric crawler if your serious about crawling? |
| | #4 |
| Quarry Creeper Join Date: Jun 2004 Location: Ventura
| by sliding clutch do you mean a centax clutch, and if so it is still a centrifugal clutch. I have heard of someone makeing a magnetic clutch, that would allow for smooth power delivery(that would probably ruin the electronic gear). But even if you did come up with some ingenious clutch system, you would have to come up with an extremely low crawl ratio, probably like 400:1. And a fuel system that can run at any angle, meaning a mgt tank or a alirplane tank (which are hard to refill quickly). I could keep going, but you get the idea.... |
| | #5 |
| i want a truck that can crawl as well as bash, and the x-factor just seems to fit also i just sold all my electric stuff (batts, charger, etc) as well as my custom Stampede with dual batteries, 13T, masher 2ks, new shocks etc..... i stopped RCing for a few months cuz i got into paintball, but then i decided to buy a nitro stadium truck, i got a Maximum ST.....i romped it like hell and loved it, then i blew the motor so i swapped in a .21, a few steel spurs later i sold the truck as a rolling chassis. now i have a Nitro TC3 on road car that i'm going to try and race. i was reading RC Car Action and saw a review of the X-Factor, i loved it. so i started reading up on crawling and it looks like a ton of fun. the main reason i don't want electric is the run time problem. i could take my ST to a track, or some other place with nothing but a gallon of gas and a few C batteries for the igniter. and i'd spend the whole day romping. with my stampede even with dual batts in parallel i could never get more than 15 mins out of them before a recharge. and i could never recharge "in the field" so that limits me to either a) a bunch of batteries or b) bashing in my yard (in the middle of suburbia) on top of that you can run a nitro engine non-stop for several hours, an electric motor has to cool down and can burn up easy, as well as the batteries 1 good battery is $40, 1 gallon of nitro is $20 good charger is $70, a starter box is $40 (ebay what what!) ESCand motor are easily over $100, the x-factor comes with a motor (and a good one at that) besides, once you go nitro, you don't go back. it'd take a lot to make me go back to electric, like sex with Lindsay Lohan.... besides, i like challenges, there aren't many good nitro crawlers, and i've been drawing up a lot of design ideas for the X-F. |
| | #6 | ||||||||
and you still need 1 or 2 batts to run that starter box and a charger for those batts. Quote:
lets see one of those designs! | ||||||||
| | #7 |
| oh yeah, my starter box runs of my car battery.... but anyway, i never knew that you guys got such good battery life! an hour, thats crazy! but for some reason i just feel more comfortable with nitro. both have been around for awhile so both power sources have been refined very much. i guess it comes down to what's best for this particular type of RCing. while electric's make great crawlers, i want to make a great nitro crawler, and if i don't then i'll switch to electric, how about that? i just want to try it. besides, others can learn from my mistakes EDIT: i made a new thread with one of my ideas |
| | #8 | |
| I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
Batteries are re-usable, have you found out a way to re-use gas? If so, I'd really like to know how. I can reuse my batteries for several years. And the batteries I run (which work excellent) are cheaper than a gallon of nitro ;) The X-Factor is like a 400$ truck.. I would hope it comes with a motor! NITRO SUCKS! I can also go out at 3am and run my rig without my neighbors hating me | |
| | #9 |
| you can only run at 3am if you remember to turn on the charger at 2am |
| | #10 | |
I keep several charged batteries around... I have 8 3,000 mAH+ packs | |
| | #11 |
| ^^ i've got one gallon of 20% nitro, $17.99.....days of bashing my TC3 |
| | #12 | |
Anyway; good luck on your nitro ventures ;) | |
| | #13 |
| thx, if it doesn't work i'll let ya know. but if it does work i'm definately gonna tell you. it should at least be a lot of fun. i'll keep ya updated |
| | #14 |
| Pebble Pounder Join Date: Aug 2004 Location: orange county n.y. , building the hydro crawler
| Ive run nitro and have gone back to electric, thers nothing like the torque of an electric motor and reduction crawling insane things and just not stoping until something breaks If i have the free time ill do a wright up on this for you if you would like. pm me. |
| | #15 |
| check pm box |
| | #16 |
| Im making one out of a maxx diff because everyone has a few and they seem plenty strong. Do you have any 1:1 wheeling/crawling experience? What the basic design is to build a pinion brake. The diff is used in a way that the imput power from the motor goes in one outdrive and power to the gear reduction/tranny comes out the other. When the pinion brake is locked power is directed through the internal diff spider gears and to the tranny. (clutch engaged) When the brake on the pinnion shaft is relesed it allows power to insted rotate the diff housing and pinnion.(clutch disengaged) It is a rather simple concept once you understand what in talking about.Pick up a diff and mess around with it and youll see what i mean. The pinnion brake would be operated like any other nitro brake with a servo. A must have would be lots of gear reduction because as the power flows through the spider gears the ratio is doubled. I would install 3 gd600s inline or custom make a gearbox is what id do to make up for the high revs of a nitro and doubling of ratio. |
| | #17 |
| Rock Crawler Join Date: May 2004 Location: DFW, Texas
| I don't think anyone answered your original question about the sliding clutch. Here's a link. http://www.hobbypeople.net/gallery/149596.asp You can see that it's just 2 big clutch shoes that slide the opposite way from each other. With more surface area they grab better than most 3shoe clutches I've seen and is an excellent upgrade from the stock shoes the xfactor comes with. It has lasted a long time as well. Over a gallon run and it's still strong. This is the best r/c clutch to buy for the xfactor IMO. For rock crawling purposes you will need something better however. |
| | #18 |
| yeah, i've seen those b4, just never knew what they were called. sambmx told me about making a clutch out of a differential. that sounds like it would work great. i'm just worried about mounting, hopefully i can find room |
| | #19 |
| Newbie Join Date: Jan 2005
| I dont know if this sounds stupid but, here is an idea I have on the manual clutch idea. Use a bearing on a lever which is activated by a servo on its own channel. It could roll on the slipper clutch and when you engage the servo the slipper is then engaged like a real clutch. I will try this if any of you think it could work. I have an XF-2 with 8 shock set-up, diffs locked, modified savage tires and wheels, helicopter header tank, computer case fan for motor, JR 7 channel heli radio, independent 4WS, and 25% racing fuel. Still looking to drop the gear ration. Any advice or imput is appreciated. |
| | #20 |
| Newbie Join Date: Sep 2004 Location: Tucson,Arizona
| Hey Junior I would be interested in the out come of that!!! Let me know how it turns out . |
| Thread Tools | |
| Display Modes | |
