11-29-2006, 02:47 PM | #1 |
Pebble Pounder Join Date: Feb 2006 Location: the race track
| Nylint tires on xf??
is it possible if so how..
11-29-2006, 04:51 PM | #2 |
RCC Addict Join Date: May 2006 Location: Aroostook county
If it's possible, they're not just going to "bolt" on...more then likely you'll need adapters.
12-05-2006, 05:13 PM | #3 |
Quarry Creeper Join Date: Dec 2005 Location: Winston Salem
adapters? whats that? i used a set of maximizer beadlocks.
12-08-2006, 01:35 PM | #4 |
The Nylint rim isn't the same size on both side's, so you have to use the stock rims. |
12-08-2006, 02:28 PM | #5 |
no adapters needed! lol...if you have a razor and some CA glue Cut the outerbead off and glue it to the rear..then it will fit on Maxx size rims. just for the people who dont grasp the obvious as quick as others...you need two sets of nylint tires. |
12-08-2006, 02:39 PM | #6 | |
12-08-2006, 03:15 PM | #7 |
Quarry Creeper Join Date: Feb 2006 Location: Shillington
12-08-2006, 04:01 PM | #8 |
gotta be careful i give my secrets out too :-P
12-08-2006, 04:48 PM | #9 | |
12-16-2006, 01:27 PM | #10 |
Pebble Pounder Join Date: Sep 2004 Location: Livermore, CA
I suppose you want to go with set of Nylint tires/wheels basically because you have them or can get them for cheap. With time and patience, you can come up with some kind of adapter to simply bolt these bad boys onto your rc. However for the time and money, I would just go with beadlock'd wheels and moab XLs. My .02
