Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: Project Old Tech aka POS
Old 01-30-2005, 05:11 PM   #1
Default Project Zip-Tie
Specs:
XF axles
E-Maxx tranny
TXT frame
Stock LST tires
Single Trinity P2K motor :-(
LRP IPC Sport esc :-(
Airtronics XL2P radio :-(
Airtronics 94102 servo :-(
Overall Length: 22.5”
Overall Width: 16.72
Wheelbase: 16”
Under Belly Clearance: Sits at 3”
It has an inverted tranny and all down travel. About 30% of all the fasters that hold it together are zip-ties
Pics:
Body- still need to be mounted
Ziptasim-
Last edited by NeoSlayer888; 02-06-2005 at 04:59 PM. Reason: More appropriate name
NeoSlayer888 is offline   Reply With Quote
Old 01-30-2005, 07:13 PM   #2
looks nice might want to lower the battery for a lower cog.
mike is offline   Reply With Quote
Old 01-30-2005, 09:51 PM   #3
2006 2.2 National Champ
BENDER's Avatar
Sweet, I like the paint job w/ that chassis looks sharp. Call it project "zip-tie".
BENDER is offline   Reply With Quote
Old 01-30-2005, 10:00 PM   #4
I like the sound of project Zip-Tie
Old 01-31-2005, 12:52 PM   #5
Talking
Sweet, I like the jeep body, nice paint, good looking truck.
(Project Zip-Tie, that is Fuuuunnnnny)
Nitro is offline   Reply With Quote
Old 02-01-2005, 09:56 AM   #6
i think you should raise your cog to 4 1/4 to 4 1/2
1beatjeep is online now   Reply With Quote
Old 02-01-2005, 08:16 PM   #7
Do you mean increase the underbelly clearance? COG is center of gravity.
Old 02-02-2005, 08:58 PM   #8
TEAM MODERATOR
Reflection's Avatar
Raising your belly clearence would be good. Mine sits right at 5" and I drag the hell out of mine. Coarse thats probly not helped much by my 18" wheelbase.
Reflection is offline   Reply With Quote
Old 02-06-2005, 05:13 PM   #9
Default New Direction
Thanks for all the replies. I realize how low it is; I designed it for a low cog at the sacrifice of everything else, such as ground clearance. That is why I inverted the tranny and used limiter straps to keep the driveshafts in.
I have decided to take my crawler in a different direction. Looking at the comp rules I think an X-Factor would have a difficult time without extreme modification. So I am going the scale tuber route.
1:6 Scale, numbers are relatively accurate
XF
Kongs: 8.5”
Axles Width: 13”
Wheelbase: 20.5”
4-Link Size: .3125” 5/16” or .375” 3/8” Aluminum
Real
Tires: 52”
Axle Width: 80”
Wheelbase: 125”
4-Link Size: 2” DOM
Actual size:
Based off of:
http://www.pirate4x4.com/forum/showthread.php?t=274002
Old 02-07-2005, 12:22 AM   #10
Default Mount
SolidWorks model of the axle 4-link mount prototype:
Real version:
On Tuesday I will see if Mat can machine one for me, or if I will have to breakout the hacksaw.
Once I get any actual piece made I will start a new thread.
Old 02-07-2005, 12:26 AM   #11
Looks pretty good. Is it in running order? If so, we should go crawling. I'm right down parker road past arapahoe, and there is a pretty cool crawling area over here by the Parker recreation center. PM me and maybe we can set something up. I'll bring the video camera
Plays_with_Toys is offline   Reply With Quote
Old 02-07-2005, 12:46 AM   #12
It can be in running order if I put the axle back on, but it’s not in crawling order. Batteries die in about 5 minutes, no reverse, no power, tires barley turn on a countertop. I would like to see your crawler but school is kicking my ass. Physics and pre-calc tests this week and three AP lang essays due within the next two weeks. If grades drop again crawler goes away
Old 02-07-2005, 12:56 AM   #13
HANG ON TO YOUR GRADES! One lesson I learned the hard way (or else I'd be up at CSU still). When you get some free time then just PM me. I'm actually pretty busy in the near future (girlfriend+vday, dad flying in, work, school) so maybe in a few weeks.
Those AP classes kick butt though. I received 6credit hours (two classes) worth of english and 6credit hours of german for my results. I just wish I had taken the physics and calc tests, but I didn't think I could handle them.
