12-23-2006, 11:59 AM | #1 |
Pebble Pounder Join Date: Feb 2006 Location: the race track
| help with mounting links on my xf axles...
my top link mounts are broken off. i need help with mounting them Here is a pic to show u what i am talkin about. also i am thinkin of mountin my servo(it a jr metal gear servo 590) on the axle how could i do that as well...later on i am goin to go chassis mounted 1/4 scale servo. http://img80.imageshack.us/my.php?image=dcp04171ts7.jpg |
12-23-2006, 03:39 PM | #2 |
Pebble Pounder Join Date: Apr 2006 Location: Mesa
I have 2 different methods I have used without breakage. One, use 1-1/2" long screws to hold the links directly to the axles at the mount holes where the mounts would normally go, This is a desparate measure that limits articulation but it works in a pinch. Two, using your favorite fab material i.e. cutting board/kydex/aluminum, make your own link/shock stays. This way keeps your articulation. |
12-23-2006, 11:02 PM | #3 |
Rock Stacker Join Date: Oct 2004 Location: Santa Clarita, CA
You can also cut off the other mount, put longer screws in the four bumper mount holes, and build a plate that spans all four screws. This plate can be used to both hold the servo in a new, horizontal orientation underneath, and build small standoffs to connect the upper links to on the top. I wish i had a picture handy to illustrate better, but think kinda TLT style.
12-31-2006, 01:08 PM | #4 |
Quarry Creeper Join Date: Feb 2006 Location: Surrey B.C Canada
| This is how I mounted mine I mounted the top links to the servo housing (running 1/4)scale and the lower links run to the shock mounts seems to work fine good flex I hope this helps |
12-31-2006, 01:09 PM | #5 |
| Heres a flex pic |
12-31-2006, 09:37 PM | #6 | |
01-03-2007, 03:35 PM | #7 |
could somebody make me a set of them???
01-15-2007, 07:01 AM | #8 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
Hmmm. mjh, I like how the servos are mounted on top of the axle. Looks like I have some work to do.
