01-05-2007, 10:53 AM | #1 |
Pebble Pounder Join Date: Feb 2006 Location: the race track
| axle tubes
i need some xf axles tubes i have looked all over and cant find were to get any were can find them at??? ----------------------------------------------------------------- |
01-09-2007, 10:40 PM | #2 |
Any body know were i can get some???
01-10-2007, 05:08 AM | #3 |
RCC Addict Join Date: May 2006 Location: Aroostook county
Build some! |
01-10-2007, 06:54 AM | #4 | ||
I typed "XTM X Factor" in the google search box.......The first link on the first page,clicked it and on the first parts page FOR the X Factor....WALLA,axle housings. Took about 5 seconds | ||
01-10-2007, 11:03 AM | #5 |
RCC Addict Join Date: Sep 2005 Location: Behind the torch!
I thought I was the only one who crawled with an X-factor, oh well. This might help: http://globalservices.globalhobby.com/part/145642.asp The "X" axles are pretty tough. My only complaint is the set screws tend to work themselves loose, leaving you with 2 or 3WD! And they're very wide, but if your not competing it really doesn't matter about the width. |
01-10-2007, 03:56 PM | #6 | |
X axles are tough,but like you said,they are way to wide and the set screws are aggravating at times. Twin axles are a MUCH better option. Depending on the gears you run,you will have a stronger gear on in your diff. There different gear ratios to pick from FOR the diffs EASILY made into custom widths Allot more ground clearence and they are HELLA stout I'm running a 2 horsepower outrunner in my Twin and it's just begging for more | |
