Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > XTM Crawler
Thread: 1/4 scale servo mount
Old 06-21-2004, 10:09 AM   #1
Default 1/4 scale servo mount
Has anyone mounted a 1/4 scale servo on the x factor axle. I dont have alot of money and the hitec 705 is cheap for 200oz. I was thinking of cutting a larger hole in the stock mount but I looks too close so I was wondering if it can be done.
thanks
rcracer is offline   Reply With Quote
Old 06-21-2004, 10:15 PM   #2
31st place in 2006 Nats!!
toyofast's Avatar
Default Re: 1/4 scale servo mount
Very simple mounts.... basicly just some aluminum strips
I need to rework them to gain a bit more clearance, but this setup has held even when being smashed into rocks.
toyofast is offline   Reply With Quote
Old 06-22-2004, 01:49 AM   #3
toyofast,
How well does the servo hold up to abuse with out a servo saver on, and does it give in any from the jumbo kongs. im thinking on doing this on my twin x. those are good lookin mounts . thanks
Rene is offline   Reply With Quote
Old 06-22-2004, 09:27 AM   #4
thanks toyo
Old 06-22-2004, 08:10 PM   #5
toyofast's Avatar
Originally Posted by slbks5
So Tiny!!
RRRRRIIGHT! Feeling small aren't ya
Originally Posted by Rene
toyofast,
How well does the servo hold up to abuse with out a servo saver on..
Not sure you can even get a servo saver for this big 'ol servo... It's a tough servo.
... and does it give in any from the jumbo kongs.
With 222oz.in @ 4.8V it moves the Kongs without any issues... fast and powerfull. The added heatsinks on it seem to really help it stay cooler as the Kongs and locked diffs do add some resistance.
The servo it relatively cheap for so much servo, about $60. I plan to get another one for the rear once I have more power to supply to my servos. The Super Rooster can't handle even this one servo very well.
Booty fab only looks good in pictures
Old 06-22-2004, 08:41 PM   #6
I ordered the hitec 705mg, I hope my super rooster can handle 2 of them. I'm using a 7.2 6 cell to power my servos now, (hitec 645, hitec 5645) no probs yet
Old 06-22-2004, 08:49 PM   #7
toyofast's Avatar
If running dual servos and plan to do some hardcore crawling I would highly suggest either you invest in or build a reciever pack to supply full power to the servos. Your run time will thank you.
Old 06-22-2004, 09:26 PM   #8
currently i think i have that set up, one 7.2 to the esc, and one 7.2 to the reciever
Old 06-22-2004, 10:43 PM   #9
toyofast's Avatar
Can your reciever handle that much juice? I thought that if you went much over 6V it can cause problems....
Old 06-23-2004, 07:30 AM   #10
So far it has without a prob, I was using a TQ3 for a while and that was great. Now I'm using the futaba Conquest for a tamiya busier, the 4 channels are great!
Old 06-25-2004, 12:40 AM   #11
im runnin two rx packs in parallel and am getting no problems and longer last and mo umph. It is a nitro and dont know on electrics just my non sense
can you tell more about the heat sinks im intrested
the servosaver at the LHS that is black and has three hats for all diffrent servos can fit the big servo without the adapters
ther is a high tec servo for about 42 it may be the same specs. you can find at servocity.com take a look
Old 06-26-2004, 12:10 AM   #12
toyofast's Avatar
On mine?? If so.... the heatsinks are a factory deal. I got the one with heatsinks on purpose as big tires can make even a big servo get warm.
But how well can those savers fit one with a metal output?? It'd need a metal/aluminum insert to handle the power and strain. Otherwise it'd strip out.
Old 06-27-2004, 01:42 AM   #13
Oh I understand now, Thanks.
