I can send to an APO. Did you follow the instructions that my site gave you when it said no shipping available?
I am running 5t pullers in my berg. They fit will the lower links outboard on the mounts.
What gearing and voltage are you running? Tis a smooth combo straight out of the box, maybe some binding in your drivetrain or a gearmesh issue? Possibly your radio? Have you reset your throttle endpoints?
What pinion are you running in your Bergs?
Hi I got the Holmes Hobbies Sidewinder 1/10 ESC but the thing is i am bit confused thats what i am using
1. Tamiya CR-01 Stock
2. Sidewinder
3. Futaba 3pm
4. 11.1V Li-po Cell
after i calibrate the ESC on Throttle and reverse and natural when i push the throttle it responds with Jumping forward its like i am pushing in and out the throttel same on reverse Please i need help am new to Electronics'
Do any of your motors have aircraft applications? I am particularly looking for an outrunner to spin a 9x6 or 10x5 direct drive prop on an 16 oz 3D aerobatic plane. Mayb the Revolver Black?
hi im new here i was wondering what motor do you recomend for a pulling truck. it has a pretty high gear ratio and it can only run a 10 tooth pinion.
John,
I know... the title sound like a bad Western movie but...
I have a Sidewinder and a Revolver. Apparently they each came with differ banana plugs, the Revolver has the 3.5mm and the Sidewinder has 4mm (?) and these don't fit together. I have the female bananas that you supplied with the motor.
Can I just cut the plugs off of the Sidewinder and replace them with the plugs you supplied or should I de-solder them and replace them?
Hello John, at first I thought my motor/ESC choices were set in stone, Novak 55T/Rooster Crawler. After months of reading threads and following links, I am more sure than ever I was wrong. Can you help me?
I am looking for a motor/ESC combo that will give me stump pulling torque, not looking for tons of wheel speed, I have 2 brushless VXL trucks for that.
I could use an ESC that has the versatility to run brushless & brushed, I have an extra brushless VXL that needs ESC only and could swap between 2 trucks, just reprogram. I am not firm on brushed & brushless capabilities though.
Another concern I have is that I currently have no plans on running LiPo, I share the hobby with grandson and like to keep it simple. I have 4 x 6 cell 5000 Mah NiMh & 2 x 7 cell 4600 Mah NiMh (Too Much ?).
My motor/ESC combo will be used on an Axial ARTR, Spektrum DX3 and stock Z590 steering servo to start with. At this time I am leaning towards the CC Sidewinder or CC Mamba Max (overkill ?), and perhaps 7T Puller. Also wondering if your 540 Torquemaster Pro may fit the bill?
Could you give me a couple scenarios with the Puller motor combo and recomended ESC and maybe the Torquemaster Pro and recomended ESC combo. Will these choices work with my current batteries? I do plan on getting some saddle packs in the near future if you recomend.
I know this is alot to throw at you, any assistance or suggestions would be appreciated.
Steve.
Hey John, I was curious if the 454 cobalt puller will work in the losi mrc.
mr john. can the mamba 25 be used on brushd and brshless?
:roll:Hey JRH would a HS 645 MG run on my stock AX10 electrics just wonderin
