any one have any experience w/ their castle creations 9000kv motor?
i just saw it on their site but cant seen to find it again
I thought the general rule of thumb was 50,000 rpm's max (due to the bearings in the motors). so with a 9000 rpm/v motor you should only run 6V max.
gear down, volt up "thumbsup"
I'd say go with the VXL motor (3500kv) or the 4600kv and a 4s lipo
this will keep everything pretty cool and last a long time.
Where did you get that info from ???
3,500Kv x 14.8 = 51,800
4,600 Kv x 14.8 = 68,080
Sorry, but that will not stay cool for long. :roll:
WOW, thats gonna get hot. :shock::lol:The old castle motors were rated for 60k max. The new rotors are rated at 100k rpm.
yup thats it
thanks for the link"thumbsup"
im going to be puting it into a traxxas slash. honestly i dont even think im going to be using it to its full potential very often. at the monment im running a stock slash w/ a seven cell (*sometimes eight) and it seems plenty fast. w/ a new brushless system especially the 9000kv im probabbly going to keep it at 50% - 75% at most for longevity, but once in a while i want to able to "whip out the bull's balls" when i want to do some speed runs or show off a 12 year old thats running an e revo thinkin he's the s**t 8)
I have the small CC 9000kv for the 1/18 stuff.....FAST!!! I run the 7700 in the on road stuff.....and they are to fast!
A 9000kv motor is a very poor choice for a Slash.
listen to holmes i think he would no what he is talking about. I got a cc4600 on a mamba in a slash and its really all u need...
...I mean i dont think ur going to be making high speed runs for your youtube buddys.
.... please elaborate
A higher KV motor has less resistance, so higher amp draw does not indicate more heat.
I do agree there- as you put additional load on a motor it will heat up because of the increased amp draw. A CM36 can only push a vehicle so fast before overheating, this much will not change. You will just be able to hit XX miles an hour on a lower voltage. Harder on the battery, harder on the wires, but motor efficiency will not change.
Take a pede and gear it for 40mph with a 7.4v 6900 and 11.1v 4600 system. The motor heat should be the same. The 6900 system should be more nimble from the lighter weight. The 4600 system will have 1/3 longer runtime from the additional watt/hours added in the pack.
