some87
is there anything in comp rules that says you cant use a tire spray?
A question i have is why do you want more traction on a clean & weathered rock than you already have? Sometimes you have to much grip on the outcrop or the off camber turn, sometimes you may want a little slip. All that traction compound does is soften a allready soft compound. If you want to try something , get a little diesel fuel & dabb it on about 30 mins before you want to test & put them in a zip-lock bag until you run & see what happens.Why would you want stuff on your tires that attracts dirt?
Speaking of the price of tea in China!I am now running the Trinity memory foam and like it a lot. It is a bit firmer than the proline/panther. Also their Intellect lipo batteries are fantastic!
- David
Over time I have come to a realization that water and soap are the best things that you can do to your tires if you want to clean them, or prep them for a comp.
