My charger won't do that. I can ship it to you and you can look at it. Just send me your addy.
john Holmes
716 W. Sexton rd.
Columbia, MO 65203
Be sure to include the problem in a note.
The 10t puller that I got from you last month is making noise. I have only ran it three times. To me it sounds like the shaft is loose in the bearing and is tumbling around in the bearings. It doesn't feel loose. The motor makes this noise at half throttle forward and full in reverse. I can send a video to you if you want. I just want to catch if something has gone wrong before it gets really bad.. Know what I mean.
They can be noisy at certain throttle settings, especially half throttle on Castle ESCs.
Are you talking about fast wear of the brushes, or the whole motor burning up? I love the motor, and don't have an issue with replacing the brushes every 2 or 3 months, or even the whole motor once a year. I just don't want it to suddenly die in the middle of a comp or trail run, I just want it to be reliable. Will I just see a reduction in power when the brushes are getting worn? How will I know when it's getting worn out?
Wear on the comm and brushes is what I am referring to. You will just have to keep it clean and drop in new brushes every few hours of use.
john, do you keep records for your customers and what you programmed their electronics too?
I don't. Your servo is buzzing because it is trying to find center, it is normal.
its the one with the silver and blue can with the shaft that is held in with a set screw. i pulled off the sticker that was on since all the letters were gone and it had some other name on it but i cant remember so ill look it up tomorrow.
It sounds like an old waypoint motor. it uses a 3mm shaft, the replacement can be found here
http://www.allerc.com/product_info.php?cPath=7_112&products_id=2660
I was $8 short on my paypal for a week....lol.
now I got the funds but you're out of Mamba Maxs.
any idea when some might come in?-will they be that same great price?
(I was kicking myself in the head, and I'm sure I just missed the last one)
I may not carry the MM again, I have another ESC coming out soon that will be better.
John, I am looking to replace my Rooster 55t with a Sidewinder and a Torquemaster 35t.I am using 2s Lipos on an Axial crawler.I would like to gain a little wheel speed. Is this the right combo, or would you suggest something else.Thanks
That sounds great to me. The 35t is nice and peppy on 2s.
John I am a little concerned about dropping in the 45t p-94 I bought from you along with a sidewinder a few months back into my new losi comp crawler for fear it will fry it. Thanks.
I don't have one, but I do know the brushed motors get hot. If you keep an eye on the temps there should be no issue, but you may be limited to 15 minute runs or so.
I am just getting a tekin fxr 45 turn combo and I am trying to buy one of the cobalt 7t from a guy from the forms. I was wondering If I could use the battery back I have now. They are 2700 mah 7 cell nimh AA packs.
Also what would the difference in run time be from a 5t 7t and 10t.
The AA batteries will get killed fast, they are high resistance.
The 5t would give the lowest runtime, the 10t the longest runtime. I can't give estimates, it depends on how you drive.
Hey John, curious as to how things are coming along with your Torque Master BR ESC...
It is coming along, I just don't quite have them ready yet. I should have more details later today.
motor hesitates when im trying to crawl:-(
im running a sidewinder with a 2c 4000hv pack from max amps.
batteries are full charge,i even tried resting the esc.
any suggestion on this john.
If it is a brushless motor, it is the nature of the sensorless startup.
Hi,
Im looking for new motors and have a question about the Puller 500s
My current setup in a Berg:
PolyRC 4s 2200mah lipo
Sidewinder/CC BEC
35t Warrior IIs
I was curious if the Cobalt 500s would handle the 4s pack? The truck is on the lighter side for a Berg....or would it still just be asking too much from the smaller motors?
Thanks
I have run them on 4s, but they don't like it. 3s is better suited. The small motors do fine if you give them a chance to cool down.
I just got my mini torquemaster the other day broke it in on my motor break in thing and got it installed in the crawler yesterday. I took it out for a test drive today on the rocks and I kept having to give it a push to get it going. It only happens when you stop and not every time. Do you have any ideas? I guess it is still under warranty since I just bought what do I need to do?:-(
If you didn't get the silver brushes with your order, I have sent out replacements as of this Saturday. This may fix the issue. If it doesn't then you can send it back.
Do you have an ETA on when your 1300 2s LiPos? Can I pre-order two or be placed on a waiting list for two?
A friend hooked me up with his spare and I am beyond impressed "thumbsup", can't wait to get my own.
A few weeks now, I am getting plenty on order so there won't be an issue with stock again.
