engineerjoe
Haha Well it is not a nitro boat!
It has a Zenoah (thank God) but in the boat scene, they want you to be able to shut the engine of with the transmitter. Also handy when your boat flips! that way the amount of water IN the engine won't be as much... So the engine runs steady because of the position of the servo. If you hit the break the engine will drop in revs and stops.
With a normal servo, you throttle and break (1/6 scale cars).
But on a boat, it is not handy that when you break by accident, the engine stops. So I want to be able to throttle as in a normal rc car, but when i accidently hit the break the servo doesn't move backwards. That should only happen when I push a button...
Hope it is a bit more clear know! 8)
I'll check the manual again, but the last time I couldn't work it out.... If anyone knows how to make this set up work, feel free to post it! "thumbsup"
I use the AT-Start (engine cut) function on my 3PK for my boat with an RCMK. Basically when you push a button it puts the servo to a preset location that is not dependant on the EPA's. That way you can adjust the EPA's so you don't kill the engine by accident.
