Tommy R
LOL. I had the same question and was about to go search out the answer this morning. "thumbsup"
Tommy, where are you making contact under compression? EDIT: never mind, I found it here. You and I look to be in the same boat; we need to fit too much burly in too little space. Hey, that's not necessarily a bad thing. Better than under-building. ;-) The rig(s) looks great, including your other project. Keep up the good work, dude.
I should get some updated pic of the front linkages. I think right now under straight bump the track bar contacts the axle housing and chassis simultaneously. And at the same time I think the drag link and tie rod are just touching. Under max articulation, I believe all clearances are good and it's the shocks are the limiting factor....which is the way I want it. I'm also toying with adding some more upper shock mounts to allow more droop travel and less bump.
Thanks for the kind words, too.
