stelerzman
here are the parts i used on my build, along with some i made .
Axial Xr10
ax30519 6x101 tube (30 degree) bent links for uppers
ax30469 machined bent link for the lower
futaba 4pk
CC 10 amp bec
hitec hs 7980 th hv servo
HOT RACING
axr2101 alum high steering knuckles
axr1901 alum c-hubs
axr2201 alum rear axel lockouts
scp1001 12mm clamp on hexes
saxr36fg lt. weight cnc steel final gears
saxr1000t lt. weight cnc steel gear sets
acer ceramic bearing set
tekin 35 turn motors, and fx-r esc's
traxxas revo steering linkage turnbuckles and rodends
hanger 9 clampon servo horn
hotbodies roaver in rear-stock foams
sedonas in front memory foams
losi gold springs front, gray in rear
tunigy 40c 1300 mah 3 cell lipo
rccrawler's jeepndoug spring retainers all 4
CUSTOM PARTS
electronics plate, battery holder,steering knuckle plate,body mount,wheel weight, motor skids,receiver and esc mounts.
Axial Xr10
futaba 4pk
CC 10 amp bec
HOT RACING
axr1901 alum c-hubs
CUSTOM PARTS
