Nothing comparable in that box I sent ya? I wonder what number Fantom is similar to the 766!!!
I looked, and wondered the same thing, then said eff it, 767s on both sides. Which bring me to a question... asked below.
PM me and I will cut you a deal on a ton of them......same with the 729 version.
I just wanted one, to try for less comm wear. Don't really need a ton. :mrgreen:
The question I have regards spring tension. I went retarded reading old posts about 19 turn motors and brush and spring set ups, over informed myself. I kept coming away with more tension on the positive, less on the neg. Nothing we all haven't heard before. I broke out my 'Tedrockz Box Of Springs And Brushes' and Fiddle Stick'd a few and put 7.0 on the positive, and 6.5 on the negative. Purple and red, tweaked a tiny bit to get exact numbers. So the question is, in general, are the crawler guys over springing the motors? And if so, is it for no reason other than improved drag brake performance? Cause my Losi does that in the axles, so I'm thinking, lighten up on the springs a little bit and save my comms. Users of other trucks could increase the drag brake in the controller a little and lighten up in the spring department and save those comms all the same. Or, is there an actual torque increase with these super stiff springs?
