T1E ''Ti Fighter''
No,I haven't tryed it that thin. I think that would be to thin and brake out or crack.
...and it'll only save about 10 grams:shock:
never mind:oops:
You guys might wanna check out dragonplate.com they have some of the best CF available!
Hey Greg, if you were to use the shocks that you are running now with the stock berg axles, what springs and oil weight would you go with? Thanks!
Thanks I'll check them out.
Probley start with mini t rear blue spring f+r with 50wt oil f+r.
Greg it looks like your new set has 1.7 oz per wheel. Have you found running a rig that is mid 4 lb doesn't need over 2 oz per wheel?
Thanks
Any last minute changes before Az since you got your butt whooped by a V1 T1E Berg? :mrgreen::mrgreen::mrgreen::mrgreen::mrgreen:
Got my new weight rings made so you better look out now. You should no things aren't always what thay seam tobe with me.:mrgreen:
looking good greg see you in a week"thumbsup"
Thanks, I cant wait.
Here some pic's of the new weight ring's. I can add up to 6.5oz per side now:shock:.
Thanks Shelby for the part number "thumbsup". I found a thicker ring too it's 1.5oz.
Got my new weight rings made so you better look out now. You should know things aren't always what they seem to be with me.:mrgreen:
The more time I spend with Greg the more I learn this is sooooo true:shock:. I am so excited for all you Texas guys headed to Arizona. As always, I wish y'all the best of luck"thumbsup"
What does it look like with a wheel on it :shock::shock:
Very cool on the weights. Couple of questions. What width does this put you at? Where did you get that washer?
