xThexFearedx
ok thanks so far I am really loving the 4pl but my dad has a 4pk and I noticed those numbers on there. Thanks anyways I was just wondering if that was possible, Nick
looking to upgrade to a lipo any suggestions in size, or should I stay with the 4 AA?
You can upgrade to a 4PK LiFE pack. Don't go to a LiPO.
Is it possible to make the 4pl show you how much mix you have engaged? Like on the 4pk when you mix there is a number that changes, is there a way to have something like that on the main screen because i dont like having to stop in a comp and pull the trigger while watching the graphs to see how much i have engaged, thanks Nick
Do you have a part number cause was on the website and could not find it.
You can see it numerically if you drive from this screen :
menu/advanced/dual esc.
It also shows you if you are in front dig,4wd or rear dig at a glance
hope that helps
I use this option from time to time also!
Does anyone ever change the direction of one of their motors while driving? by having each axle spin opposite of eachother you are able to spin the truck around without hardly moving.
There are several different manufacturers you can get them from. The Futaba battery doesn't seem to be stateside yet for sone weird reason. I would say go to your favorite retailer and search "4PK Life".
This is the battery listed for the 4PL:
FUTM1473 5-Cell 1700mAh NiMH Tx Battery
& this is the 4PK:
so both use the same battery
Pro-Tek part#(For LiFe):
PTK-LF-CTXF2100-2S
Specs:
Voltage: 6.6V
Capacity: 2100mah
Chemistry: LiFePO4
Balance Charge Plug: XH
Charge Rate: 1C
Discharge Plug: JR/Futaba
Dimension (LxWxH): 76x41x17mm
Weight: 105g
Thanks "thumbsup" found one on Amainhobbies
Did you get 2? :lmao:
I apologize for coming back to the theme of the 4PL update but still did not understand what you can not do if you have a version without update ,I'm sure the answer is in the post but have not seen it yet , I order a 4PL today , so I'm concerned about , thanks for the help "thumbsup"
