Szczerba
Looking for new treads for my xr and wanting pin tires and not sure which set to go with and whether to stagger the compound front/rear.... So whatcha think
I have both the boss claws and khaos tires in red compound. They perform VERY similar (same cut on both sets). If the course has big breakovers, I would run the Khaos, steep sidehills, run boss claws. Also the XR can get away with the shorter boss claws a little easier than some other axles.
4xFord's response is spot on. Although, I personally will not get a set of boss claws. Khoas Rover's work for me on 90% of the rocks I run. I run a soft enough front foam setup to where the height is comparable to a similiar rover or sedona setup (like Nova's Ark mentioned). You can make the rears taller with some firmer foam inserts.
I comes down to which rubber compound you prefer. Hot Bodies white, red or pink. Or Losi's Red or silver. I say Hot Bodies did a great job with the 3 compounds listed on Rover's and Sedona's so, I choose HB.
With some testing, the Hot Bodies Block truggy pin tires are proving themselves in a Red compound too!
