You can program the front wheels to have 100% while you can adjust the rear wheel speed (in your video tutorial, you made it adjustable in 10% increments), but can you do it the other way? So have the rear spin at 100% while the front is adjustable?
Ah yes, I get you now. Thanks Harley.
Hey Harley any update on those RX you were suppose to try out to see if they work with the 4PL.
Both work without a problem. I like the white one (forgot the number).
If you recall let me know want a smaller RX thank u "thumbsup"
YES!!!!!!! That's the one I was hoping for thanks "thumbsup"
The short little antenna and the way the plugs go it make it a nice little RX. Being 20% cheaper is also great! :ror:
Do you think the range is affected much with that small antenna? I'm definitely getting one of those for use in a crawler, but I wonder if it would be appropriate to use in a car run on a track.
is this the smallest one that works with the 4pl? if possible can you take a picture of this rx next to the normal one. thank you
