yes, they are a loud servo, but they work well.
Thanks 2500 dave. so yer sayin this is kinda normal. Asking cause I'm lookin at them also or would I do better with a Hitec?
Whadja use for that netting in the back?minor update, Have been working on a few low budget mods. Fabbed up a quick set of wheelwell/bulkheads for the front and rear wheels to keep the rocks out of the interior. Just cut up some mockups on stiff paper and then transfered to some 1/16'" lexan. Front bols on with stock skin and rear is ziptied in. Also did a bit of camaflage for the rear deck. I have no intentions of adding any weight up high or adding scale stuff so I just want it to look clean and simple. For now the mesh works.
Also trying out a new hood, not sure what I think. I have another donor body I am going to try to see if I like it better. Any opinions welcome.....thumbs up or down?
I assume you bought the one at Hobbytown?
Yea, thanks for the advise. I will bring it in soon. Servo seems to work great, fast and strong. Need to upgrade the servo mount with the great torque. THe mesh across the deck is some sort of garden drainage screen, and the mesh across the rear panel is from a drywall patch kit, just stuff laying around. Need a new solution for the rear deck now cause I need to clear all the electronics. Not too worried about total scale look, just want to camoflage it a bit.
Do you have any experience with that motor you referenced? Might pick one up this week.
What shocks are those?I'm Lookin for some nice shocks that are a little longer.
You are making me miss Colorado... The paint job looks great!
Please help. Just testing my new electronics setup and I need some help. I have a Tekin 17.5 wired up to a Mamba Max Pro on a 2c 5200 2500. The radio is the stock Axial Wraith unit.
My problem is that forward and reverse are backwards on the radio, but when I switch the radio to reverse the action, it works but the forward is only 30% of full throttle when pinned, and reverse runs full blast. I have tried the programming card and cannot find a setting to correct this. I double checked my wires and it seems like everything is going to the right place. Any help would be appreciated.
