losikid
Got Worms?
I'm having a little trouble hacking mine. On the last step of the instructions it says to go to program and then current tab. But when I do this I get a pop up saying "Cannot communicate with the board, Wrong board selection or check board power supply or check that a previous session is closed" So I tried what it said but still cant seem to make it work, any idea how to fix this?
Thanks
Try this
Turn radio off, make sure everything is unplugged, restart your computer
Now, plug your radio into the programmer, Green/Black wire goes towards SB on the programmer and on the towards the buttons on the radio.
Plug the programmer into your computer
Open up stvp
Open the new firmware
press program.
Its very picky in the order you do this, also if you haven't flashed it before the radio should be beeping when you plug it in, if it isn't that means you have it plugged in wrong (programmer also has to be plugged into the cpu)
