TURTLE
Gettin’ back on the horse
RPMJ showed me a used Kysoho DRX on ebay a few weeks ago. We had it listed in the 8th scale open rally class for our series, but I never thought a ton about them being a nitro and a difficult to get Kyosho car. I started readying around and looking at dimensions and learned that it is actually bigger then the HPI WR8 in every dimension. It is based on a 1/8th scale buggy, surprisingly light weight and parts are easier to get then I originally thought.
Specs:
Kyosho 1/9th scale DRX rally
Length: 563mm (22.17 inches)
Width: 260mm (10.24 inches)
Height: 187mm (7.36 inches)
Wheelbase: 316mm (12.44 inches)
Tread (F/R): 215mm / 215mm (8.46 inches)
Tire(F/R): Φ93×38mm / Φ93×38mm
Gear Ratio: 8.86:1
Weight: 2,600g (approx.) (5.73 pounds)
HPI WR8 (supposed 1/8th scale)
Chassis length: 485mm ( 19.09 inches)
Width: 227mm (8.94 inches)
Height: 172 (6.77 inches)
Wheelbase: 300mm (11.81 inches)
Tamiya DF03RA (1/10th scale)
Length: 407mm (16 inches)
Width: 186mm (7.32 inches)
Height: 155mm (6.1 inches)
Chassis weight: 1,112g (2.45 pounds (no electronics)
It starts with one.
Kyosho DRX Ford Fiesta.
Comes as a RTR nitro. The first thing I did was pull the 18 motor out and all the nitro parts. There was a list posted on Infernosonly.com with the parts needed to convert this to brushless, but as I quickly found out many of the parts were not needed. Of the 5 parts that are supposed to be used for the conversion I have only used two, the Electric motor mount and the battery tray.
Here is how it started
The mod parts
Ride height with the Nitro setup
Suspension fully drooped out
Full compression the body touches the ground.
Rear end
Front end
The front and rear light buckets are LED ready, full 3 dimensional light areas.
Size comparisons with a 10th scale rally car.
How it comes
Motor out
Radio box, fuel tank, dual brakes all out
The oil filled center diff.
The electronics already in. ;D
The motor and pinion are just for mock up I have a Mamba Max Pro and 2400KV 550 can SC system going in. Still thinking about a better servo to put in. I will be using this Max amps 5450MAH 3 cell battery.
I still need to rebuild all the differentials with better oil and add a few gears to the inside of the center diff. Probably going to make an under body as well. Hopefully the motor, ESC and MOD1 pinions show up tomorrow so I can at least take it for a short test run.
I will get some more updates soon and progress on DRX #2 soon.
Specs:
Gear Ratio: 8.86:1
It starts with one.
The mod parts
Rear end
Front end
How it comes
Motor out
