Hello everyone. I just finished building my XR10 and took it out on the rocks 2 different times with the same problem. If i pull on the trigger just so that the tires start to spin, the front always spins before the rear. Once I give it just a little more throttle the rear starts to spin. I have same pinion on both motors and I am using the 4PL radio. I cant figure this one out...
Things I have tried:
- Reset and programmed both fxr's to the same settings. One of the fxr's is older then the other(Maybe 1-3 years older) would this have any effect? (I am not using HOTWIRE)
- Tried to get both pinions meshed the same on the gears so one is not tighter/looser then the other.
- One last thing that could cause a problem maybe? I have two 45T Tekin motors, however the front motor is the older style and the rear is the new "Heavy Duty" edition, BUT yes both are 45T.
Any help or suggestions would be most appreciated!
Thanks
Thanks
