rsantos450
Hello, i whant to buy a crawler to have some fun, are these cars the same chassis? should i get a old AX10 Scorpion artc or the new ridgecrest?
thanks
thanks
The Ridgeline is an all tubular frame similar to the Wraith only in a vertical plate type set up. The AX10 is a true aluminum vertical plate type chassis and really doesn't compare to the Ridgeline.
I vote Ridgecrest for both crawlin' and haulin'.
I think you'll be happy.
Here's a comparison I wrote up in another thread breaking down the Pro's and Con's:
Original AX-10 RTR vs. Ridgecrest
Body: Baja Buzzard vs. Ford Station Wagon?!?! = Advantage - AX-10
Tranny: Spur cover + better (pass-thru) set screw on output shafts = Advantage - Ridgecrest
Driveshafts: WB8 Wildboar's vs. original plastic yokes = Advantage - Ridgecrest
Shocks: 5" leakers vs. 4" threaded bodies, less leaky = Advantage - Ridgecrest
Link setup: 3-link vs. 4-link = Advantage - Ridgecrest
Link materials: thin and flexy vs. beefy = Advantage - Ridgecrest
TX/RX: 2.4 vs. FM = Advantage - Ridgecrest
Servo: AS-1 vs. AS-3 = Advantage - Ridgecrest
ESC: AE-1 vs. AE-2 = Advantage - Ridgecrest
Tires: Ripsaws vs. Lizards = Advantage - Ridgecrest
Wheels: Renegades vs. Beadlocks - Advantage - AX-10
Axles: Thats a DRAW! Depends on who you ask. Each built for a purpose, each solid.
I vote Ridgecrest because the wider Axle + offset pumpkin seems to contribute to reduced torque twist.
Chassis: Similar widths, metal vs. composite, however, the tuning options make the Ridgecrest chassis pretty damn slick! = Advantage - Ehhh, I think Ridgecrest
Other than the Body and the Beadlocks, I think your base platform is just flat out better with the Ridgecrest, FOR THE SAME DANG PRICE as 5 yrs ago!
Basher/gofast rig or crawler, the Ridgecrest is fun either way. I'm going crawler with mine and last night had a great time.
Marcus, where were you??
