JD
My Wratingo
SCX10 Skid
4-Linked
Upper Links Straight
Lower Links Angled 15mm Balls
nemo nothing rubs at full compreshion? what are all the specs of that thing?? if i were to do the same set up but longer links for a differnt body would it end up rubbing?
Nope Nothing Rubs.
You have to do the links like this due to Drive Shaft clearance.
I am running Pro-Line scaler shocks if you try to go higher the Driveshaft CV joints bind then you have to rotate the axles for clearance witch is OK for the rear but in the front you would have to rotate the knuckles back also or your steering goes to poop.
-Ickabob is running a longer wheelbase on his. mine was kept short for the Dingo body
-Also running Low-Pro 2.2 Flat Irons If I installed Ripsaws or TSL I would have to remove the fender flairs and trim the body,
-So all things are possible.
-My Wheelbase is 295mm (11 1/2")
