Its a traxxas part, I cant seem to find the part number anywhere right now to help you out. I'm sure somebody can chime in with the correct info on them "thumbsup"
https://www.rpphobby.com/ProductDetails.asp?ProductCode=TRA3727A
Looks great Brandon! All the info I was looking for in one thread. Any thoughts on mirroring an scx10 trans under the interior? Just wondering if it'll still clear. If you had tried it. Thanks again!
man you build some nice rigs
I have not tried running the trans flipped. There might be some interference with the interior tray.
Neither. I went through some trial and error to get the wheelbase to match the openings on the body.
Keep in mind the SCX10/AX10 axles have the AX80043 4-Link Axle truss installed.
Front Lower links: AXA1427 50mm posts with AX80005 bent ends on one side, and the short bent AX80057 ends on the other.
Front Upper Links: AXA1427 50mm posts with AX80057 short bent ends on both ends.
Rear upper and lower links: AX30714 7x73 Links with the long bent rod ends from AX80057 on each end.
2X TowerHobbies.com | AXIAXA1427 AXA1427 Axial Post 7x50mm Grey (2)
2X TowerHobbies.com | AXIAX80057 AX80057 Axial Linkage Set XR10
1X TowerHobbies.com | AXIAX80005 AX80005 Axial Linkage Set
2X TowerHobbies.com | AXIAX80043 AX80043 Axial Links Parts Tree RTR SCX10
2X TowerHobbies.com | AXIAX30714 AX30714 Axial Threaded Aluminum Pipe 7x73mm Grey (2)
Ill add some pics in a minute.
Curious if you've got a pic of how much you trimmed where the tires were rubbing. I've got zero flex when the wheels turned (tires hit the chassis)
I like this build so much when I was shown Brandon's build I was inspired to build one like it.
R35 1.9 Treps
