NorCal 2500HD
First, I would like to say thank you to Axial for sending RCC an early media kit. Along with this kit, Im also in the process of building a wraith. 2 builds at one time is going to be fun.
The mandatory box shot.
Manual.
I started out with the axles, per the instructions in the manual. Got everything assembled and started digging through my bins to see if I could find something to prop them up for a few quick shots. In one of the bins, I ended up finding a set of HD Overdrive gears (#AX30401-36t/14t) and a set of HD Underdrive gears (#AX30402-43t/13t). Along with the HD gear sets I found a set of Axial Universal Drive Shafts (#AX30464). The only problem was I couldnt find one of the pins. So apart came the axles and in went the HD gear sets. As I was about to put the stock front shafts in, I remembered I had used a small pin to assemble the drive shafts in my kit Wraith. The drive shaft pins in the Wraith were the same exact size, BINGO!! Finally after awhile I got everything back together and was able to start snapping some pics.
NOTE: The HD gear sets and the front upgraded shafts are not absolutely needed to make this trail ready. The stock parts are more then plenty to go have a good time with the rig. My plan is to run a Holmes BRXL and 13t on 3s, so the added durability will def help.
I wasnt quite sure why John wanted the shocks out of the kit last night when I was at his house. I didnt bother to look until I got home. These things are pretty damn nice. Went together pretty quick and are very smooth.
After a few hours I decided it was time to wrap it up. Both axle assemblies are together along with the shocks....tomorrow I'm going to start on the transmission. "thumbsup"
Manual.
