Postclanker
Well, that didn't change anything. I got the 3rd Chanel to be at zero instead of +100 and it still spools. Not sure what to do now :shock:
Hello Harley
Today I was showing a friend how he could bind his 4pk to my truck sence I am lefty and he is right handed..after we were finished I noticed my truck will now coast when throttle is at neutral...if I go from forward to reverse instead of a solid stop it will coast.....never had this happen before... Did a setting change or what....if you can help with this please let me know thanks "thumbsup"....
I have 2 FXR ESC...I am not sure I understand what you mean by changing
The end points on them....do you mean the EPA(ATV) on the 4pk they are at: TH FRD: 100 100: BRK....
The diference between FF and FS is the dual diversity antennas. A little more money for a little more range. Not really needed for crawling. Cheaper the better.
How do I turn channel 3 into a 3 position switch ( forward/off/reverse ) using PS1 on my 4PK.
I want to use it for winch controller .
Thanks . I can1t get it .
Is there any way of setting up something on the 4PK to act as a three way switch?
So I bought a 4pk used from a friend and it worked fine for my scaler up until today. I ran our first two courses firat one was 210 gates and the second was 100 but when I plugged in to run the third course my rs speed control showed the last three lights on it. Is this a radio issue or something else?
If I'm in the wrong section let me know.
Recalibrate your throttle Position. The speed control lost it's neutral point. If it happens continually, then widen the deadband on the ESC.
Is this in the speed control or the radio. I tried to reset the speed control and it picked up neutral and forward but not reverse. I appreciate the help.
Harley one quick ? "thumbsup"
Will this bind to my 4pk.....FUTABA R2106GF 2.4G SFHSS Micro 6Ch Rx
Thanks tom
